Old 05-06-2013, 05:27 PM   #1
BigTJohn's Avatar
Pdi ok until...
Almost done w/PDI and our Columbus 320RS show only the following:
1 Wrong mattress - should be Trump
2 DS slide is not quite "level" but slide measures square and true. Floor(wood subfloor) is the problem. Dealer checking w/factory on a fix.
3 Belly coroplast heavy w/water. Must be a leak from fresh water system. Insulation soaked, will be replaced. 80% of the water was located under the fresh water tank.
Bottom line - still in Grey Wolf at dealers campsite. OK, but had hoped for better results. All can be fixed/replaced as necessary. More tomorrow.
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
Old 05-06-2013, 06:11 PM   #2
Sorry to hear about the issues on your 320RS. #1 should be an easy fix but somebody should've caught that on the build sheet while it was still on the line. Hopefully it won't have to return to the factory to correct #2. Dealer service dept. should be able to fix #3. Considering the $$ of your new Columbus I can understand your disappointment. Hopefully everything will be fixed to your 100% satisfaction.
Wiscampsin is online now   Reply With Quote
