Old 09-03-2013, 01:25 PM   #11
Dovetail's Avatar
Not to say they are bad, but wonder if they are really noisy ina bedroom?
Rick and Linda, Lindale, TX
2011 Flagstaff 8528 CKSS
2006 F350 SW
Camping nights 2013: 130
Camping nights 2014: 17
Dovetail is offline   Reply With Quote
Old 09-03-2013, 01:33 PM   #12
Fulltime family RVer
Yup. As with everything- there are always trade offs. The noise level in our bedroom is the negative.
But, truth be told- I would definitely consider a third if it were offered for the bunkhouse.
Old 09-03-2013, 02:12 PM   #13
NELA
Weezer's Avatar
Re the noise, while sleeping we use the living area a/c...both feed into the same ducting system.
Of course while not sleeping we use the one in the bedroom.
There's also the option to have them feed into the duct, or blow directly from the bottom grills of the a/c. I've found feeding into the duct to be much quieter/better, especially while watching TV.
When first firing 'er up, we open the direct vents instead of going thru the ducts, seems to cool down quicker that way.
Optional 2? absotively geaux for it! (heh, spellcheck doesn't like those words) *smirk*
Right now "Francis" is sitting in the back yard, hooked to shore power with the bedroom a/c set at 82. She's chillin like a mug....but she's also sitting under 3 huge live oak trees. If not for that she'd need the LR a/c going to make 'er comfy.
(heat index well over 100 here today)
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 09-03-2013, 02:17 PM   #14
CLASS "A" Senior Member
cfsoistman's Avatar
Definitely 2, why? If one stops working you still have the other one instead of none!!!!
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 09-04-2013, 04:05 PM   #15
SydKad's Avatar
Originally Posted by rbowles View Post
Just bought my first TT and it has a double AC. Served us VERY well this weekend. 103-105 deg outside, nice and frosty 70 deg inside!
rbowles,
I have almost the exact same floorplan only mine is the Tracer 3150BHD instead of the Lacrosse, and my unit came factory prepped for a second A/C. Since yours is also a Prime Time, I am curious about a few things:
1) Where is the second unit located?
2) Does it plumb into the existing duct work?
3) If ducted, is there a separate thermostat for it?
4) Does it help keep the bunkhouse cooler? My BH is usually noticeably hotter than the rest of the coach, which I think is because there's only one vent and it's the 4th and final one on that duct
5) Was it factory installed or dealer installed?
Thanks in advance.
2014 Prime Time Tracer 3150BHD
2013 Ford F-150 EcoBoost
SydKad is offline   Reply With Quote
Old 09-04-2013, 04:19 PM   #16
pjones1969's Avatar
Has anyone added a second AC to the front bedroom on a Sabre 32bhok? Mine is framed, wired and has a stat on the bedroom wall I was just curious how all of that worked with the duct work.
I read another post about going back and foil taping all of the vent connections because they were originally done pretty poorly at the factory, I did that this last weekend, I'm sure it helped some but not like a second AC would and a good point above about if one goes down you have another.
2011 Puma Unleashed 27SBU - SOLD
2013 Sabre 32bhok-6 - SOLD
2012 Ford F250 6.2 - SOLD
2017 Heartland Cyclone 3800
2016 Ford F350 6.7 DRW
B&W Companion
pjones1969 is offline   Reply With Quote
Old 09-04-2013, 10:45 PM   #17
jtstromsburg's Avatar
Not a 32, but a 34tbok. Same as your setup though.
1 Remove existing vent from opening.
2 find 110v power next to opening
3 find suitable 12v power in ceiling (I used the wires going to the closet light)
4 set unit on roof, centered over opening
5 line up lower flange and install 4 bolts to squeeze the upper and lower pieces together making a tight seal
6 hook up power, 12v and thermostat wires to controller and mount in lower AC unit
7 turn power breaker on and play a game of "freeze out"
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 09-05-2013, 08:59 PM   #18
pjones1969's Avatar
Thanks, sounds like about a 30 minute project, haha...... I've read that the hardest part is getting the new unit onto the roof
B&W Companion
Old 09-05-2013, 09:49 PM   #19
It can be. I used a bobcat ahead set it on from in the bucket. Easy, even by myself. My hardest part (probably cause I was solo) was getting the upper unit centered over the hole. You can't slide it or you'll lose the seal. Still not too bad
Joel and Teresa
2016 Sabre 34TBOK
Old 09-06-2013, 05:06 AM   #20
Someone here posted about making a "sled" of sorts that they were able to pull up a ladder. Kinda neat idea.
