Old 04-17-2015, 11:59 AM   #1
Retired
RubyDually's Avatar
Pleasant surprise installing JT Strongarms
With the new 33CKTS in the storage yard over the winter I ordered up JT Strongarms from Tweetys to install on a nice day.
Yesterday was that day.....
What a pleasant surprise it was when I lifted the spare tire out of the way to see what was on the other side before drilling the holes and there they were already predrilled.... Plus as an added bonus predrilled blocks already welded to the frame for the side arms along with the second from bottom holes on the legs drilled out to 1/2 inch......
Needless to say the stabilizers went on in no time flat......
Thank you Lippert for making my life easier yesterday!
2014 Chevrolet Silverado 3500 LTZ CCLB DRW D/A - Rancher Grille Guard - Transfer flow 40 gallon Toolbox/Tank Combo - Line X - Edge Insight
2015 Palomino Sabre 33CKTS - Platinum Edition - Progressive Industries EMS HW50C - JT Strong Arm Stabilizers - Ground Control 3.0 - 320 Watt Solar with 2000 Watt Inverter
RubyDually is offline   Reply With Quote
Old 04-17-2015, 12:22 PM   #2
Mr. Dan's Avatar
Good for you!
I didn't have as much prep as you but I DID have the two holes pre-drilled front and center. Even that helped!
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 04-18-2015, 08:02 AM   #3
AKA KE2DX
Don and Elaine's Avatar
Our Columbus 320rs already had 4 points ready to install the JT strongarms, I use the BAL version that has a large nut with a ratchet tool instead of the "T" handle that can fall out while on the road. Good deal on them also from Amazon.
2016 Dodge Ram Dually 4X4 Quad cab LB 3500 Cummins 6.7L TD / 2013 Columbus 320rs. Camped 50 days in 2015, 74 days in 2016, 92 days in 2017.
Don and Elaine is offline   Reply With Quote
