Originally Posted by Cuttinchief
Rather than the Honda and yamaha's what are some of the best portable generators that are quiet and reliable. Ones that can be used with some of the bigger rigs like the Columbus
you have a choice, do you want quiet or inexpensive? can't have both.
what do you want to run. if you don't need the a/c, then a 2000w inverter generator will work.
if you need to run one a/c, you'll need at least 2400w minimum if it's a 13.5k a/c. if it's a 15k a/c, then you'll need 3000w minimum.
the only inexpensive(compared to H/Y)inverter gennies that will compete are 2 Champion 2000w in parallel, the Boliy 3600(which has mixed reviews) and the Kipor 3000 or 2 of their 2000w paralleled. all of these will run you $900 or more, cause QUIET ain't cheap.
you need to provide more info, such as needing a/c and if so, how many and what size are they.
