Old 02-14-2015, 07:02 AM   #11
fonzie's Avatar
Here some reading on levelling.......
https://www.google.ca/search?q=level...EZasyASi_YDYAw
Fonzie
Old 02-14-2015, 07:20 AM   #12
Flagstaffer06's Avatar
Yes, you never want to use the stabilizer jacks for leveling. On a travel trailer they are just for stabilizing.
There is a procedure for getting the best scale weights.
Forest River Forums - Downloads - How To Weigh | CAT Scale
That's the link from the library page but, if you go through the library there are also alot of other helpful resources there too.
That will tell you alot and it will help ensure you have your hitch setup the best.
By the way, what brand hitch do you have? What are the weights of the bars? Is it a chain type? Does it have sway control?
2012 Keystone Sprinter
Still sticking around for the good people and advice.
Flagstaffer06 is offline   Reply With Quote
Old 02-14-2015, 08:05 AM   #13
danielabram71's Avatar
Not sure the brand. It's chian type. When I get home I will look and see if I can find out more
danielabram71 is offline   Reply With Quote
Old 02-14-2015, 08:19 AM   #14
No sway control
Old 02-14-2015, 08:33 AM   #15
fonzie's Avatar
This is good reading on wd hitch and sway control.....
Common Weight Distribution and Sway Control Questions | etrailer.com
Fonzie
Old 02-15-2015, 10:45 AM   #16
pappagrif's Avatar
I have the similar issue had a 2012 Chevy Avalanche with the larger gear ratio 3.73, similar to the 1500. Only difference is we have the 267 bhD version palomino with dual slides(1 for kitchen).
Ended up being a bit much for the Avalanche on long out of state trips. Moved up to the 2015 gmc 2500hd
pappagrif is offline   Reply With Quote
