Old 02-13-2015, 09:34 PM   #1
danielabram71's Avatar
Pulling my solaire 267bhsk
In August of 2014 i bought a 2015 solaire 267bhsk. Dry weight on sticker is about 5,200lb. I had a 2012 frontier but used my dads f150 to pull it. It had air bags and was nice. But in Dec of 14 I bought a 2014 gmc 1500. Has tow bottom but I have to put the hitch and electric brake in it. Was just wandering does anyone have any idea how well it will pull my camper.
danielabram71 is offline   Reply With Quote
Old 02-13-2015, 09:58 PM   #2
Flagstaffer06's Avatar
Daniel,
Welcome to the forum, we will need more information to help you out.
Body style-Reg Cab, Crew, or Extended Cab
Engine size
Payload
Rear end gear ratio
4x4 or 4x2
A quick look in the GMC literature shows the 1500 can be anywhere from 4400lbs tow rating all the way up to 10800.
Let us know, you'll get alot of help, maybe even more than you want!
2012 Keystone Sprinter
Still sticking around for the good people and advice.
Flagstaffer06 is offline   Reply With Quote
Old 02-13-2015, 10:27 PM   #3
3.42 is the gear ratio. Motor is 4.3 v6. Crew cab and is 4x4. I still need to put electric in. But I have been told that the plug for it is already there under the dash. Book says it will tow 7,100 lbs. I have weight distribution bars
Old 02-13-2015, 10:39 PM   #4
I don't have a 1500 so I can't speak specifically if the plug is under the dash but, on alot of trucks the plug is there. You''ll just need the adapter from the brake controller to that plug.
7100lbs is the max trailer weight that the truck is rated for by GMC. Your trailer is 5200lbs dry. Everyone's loaded weight is different but, a rule or thumb is 1000lbs some are less and some are more.
You'll need to watch your payload, check out the sticker on the door.
What type of hitch do you have? Brand, size? I think that your truck should tow this but, may struggle a little on some hills. If your hitch is setup properly, the truck should handle it fine.
If it's not setup properly, it could be a good handful for that truck.
There are many brands of weight distribution hitches, and they aren't all created equal.
I think the truck will do it, but only you will know for sure as comfort levels differ as well.
You can always set it all up and take it to a CAT scale too and see how you measure up. This will help with your WD hitch setup as well.
Old 02-14-2015, 07:29 AM   #5
On the weight distribution setup not sure the brand but the guy I got it from said it was for 1000lb tongue weight. I do mostly short trips around home. But will do a couple longer trips through the year
Old 02-14-2015, 07:30 AM   #6
Where can you do the CAT scale thing at?
Old 02-14-2015, 07:43 AM   #7
fonzie's Avatar
CAT Scale
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 02-14-2015, 07:54 AM   #8
Ok thinks.
Old 02-14-2015, 07:58 AM   #9
I have another question. When I level my camper is the only way to do so with board or blocking under my tires. I have the four stabilizeing jacks on it but know they are just to keep it from rocking. Anyone have any input on this as well
Old 02-14-2015, 07:59 AM   #10
Thanks I found a scale 35 miles from me
