Old 04-01-2018, 07:32 PM   #1
RAMMIN_TIME's Avatar
Puma 31BHSS A/C Not Working
Well first night in brand new Puma 31BHSS and A/C not working. Couldnít be more frustrated. Sounds like compressor not kicking on. Iíve checked all connections I could see and nothing seems out of ordinary. Fan kicks when sliding thermostat temperature. Do not see and breakers or fuse issues. I ran my power to site next to us to see if getting dirty power. Any help is appreciated! It is an Airvex 48254c869
RAMMIN_TIME is offline   Reply With Quote
Old 04-02-2018, 12:25 AM   #2
bikendan's Avatar
Did it work during the PDI/walkthrough?
Equalizer WDH
Old 04-02-2018, 06:51 AM   #3
I thought it was but when we took delivery it was cold out. I know the fan obviously came on but now not sure the compressor was. I have all my tools except left meter at home. Almost seems like a control board issue but not sure how to get it out of there.
Old 04-02-2018, 07:02 AM   #4
cavie's Avatar
are you sure you have to AC "ON" and not just "Fan only"?
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 04-02-2018, 07:08 AM   #5
Yes Iíve tripled check all that. When it is selected on AC and I slide temperature to say 85 it cuts off. Then when I slide back to 70 it will not come on until the compressor duty cycle time delay occurs. At this point I think itís the control board or wiring from it to compressor.
Old 04-02-2018, 07:13 AM   #6
cavie's Avatar
Originally Posted by RAMMIN_TIME View Post
Yes I’ve tripled check all that. When it is selected on AC and I slide temperature to say 85 it cuts off. Then when I slide back to 70 it will not come on until the compressor duty cycle time delay occurs. At this point I think it’s the control board or wiring from it to compressor.
So after the time delay does it come on fan only?
Old 04-02-2018, 07:19 AM   #7
Yes. Thereís never seems to be a time when compressor even tryís to come on.
Old 04-02-2018, 07:26 AM   #8
cavie's Avatar
Yes. There’s never seems to be a time when compressor even try’s to come on.
Probably easier to just call a local AC service shop than talking it back to the dealer. Sounds like another miswired t-stat. There is a built-in time delay once you have shut it off by sliding the temp up. 5-10 min. If the fan comes back on the comp should also. May have a compressor wire off the t-stat. Or on a wrong screw.
Old 04-02-2018, 07:32 AM   #9
Cavie thanks for your help. Has this been an ongoing issue? Itís funny you mentioned incorrect wiring, I installed the Furrion observation camera in the prewired mounting bracket. It was miswired and I had to switch the two wires.
Old 04-02-2018, 07:36 AM   #10
cavie's Avatar
Cavie thanks for your help. Has this been an ongoing issue? It’s funny you mentioned incorrect wiring, I installed the Furrion observation camera in the prewired mounting bracket. It was miswired and I had to switch the two wires.
Not ongoing issue that I know of. Just one last week. His compressor was running with the furnace on. Hot and cold air.
puma
