Old 07-30-2018, 08:43 PM   #1
Puma 32RBFQ
Any owners of the puma 32 rbfq? Having sway issues
tmhunter2004 is offline   Reply With Quote
Old 07-30-2018, 08:51 PM   #2
Hugeez's Avatar
A little more info would help us help you. What is your TV? What type sway control do you use? What tires are on your TV? What model WDH do you use?
2018 PUMA 31 BHSS
2017 RAM 2500 LARAMIE 6.4 HEMI 4X4
E2 WDH
Troy, Josie and our 2 K9 co-pilots Breck and Maggie
USN 86-92
9 nights camped so far in 2018
Hugeez is offline   Reply With Quote
Old 08-02-2018, 06:10 PM   #3
It’s 36ft 3slides on driver side we tow with cheverlot 2500hd extended cab we have the Reese straight line stabilizer hitch 1500 lbs which was not the original hitch the dealer placed it swayed the day we brought home even on the way home we called the dealer about how bad it swayed we have took it back 2 different times they claim nothing is wrong with the camper it has been towed with a long bed 2500 and it swayed some and a duley at 45mph could feel it fighting to sway they blame our truck claim it has a lift kit but it does not it has had the key turned and that’s all we are at a loss as to what to do
Old 08-02-2018, 06:34 PM   #4
Hugeez's Avatar
I would have to imagine that if the sway problem continues with multiple tow vehicles that the problem is in the RV. Good luck. Sorry I couldn’t be more help.
2018 PUMA 31 BHSS
E2 WDH
USN 86-92
Old 08-02-2018, 08:18 PM   #5
We were hoping to find someone with this same camper to see if they had any issues like this we have not been able to find any reviews on this particular model
Old 08-08-2018, 06:32 AM   #6
We have a 2018 32RBFQ, tow it with a 2015 Chevy 2500 with a 6.0.
When we took ours home from the dealer it would sway occasionally.
On wet pavement the rear tires would loose traction taking off from a dead stop.
I adjusted the bars a little as they had taken to much weight of the back axle of the truck, No issues now.
Johnv656 is offline   Reply With Quote
puma
