Old 03-19-2014, 06:29 PM   #1
Puma polish/wax
Hi,
What do Puma owners use to polish/wax their trailer? the ribbed exterior makes it tricky to work at.
Will
will2020 is offline   Reply With Quote
Old 03-19-2014, 08:41 PM   #2
WFD
I used Nu Finish and a soft cloth to apply and micro fibre cloths to buff out...working with the "ribbed edges" as you say, really not that bad. Nu Finish went on easily and gave a nice finish, but I felt that it didn't last long enough...next time I will switch product....but to answer your question with regards to the exterior surface...its does require a bit more elbow grease. Just dont try doing it all the same day...its a big job!
Rick
WFD is offline   Reply With Quote
Old 03-19-2014, 10:04 PM   #3
Missing Link
cyclepuck's Avatar
I use any named brand wax on a buffing wheel in the spring. Then rest of the year I just wash and dry with turtle wax wax and dry. Stuff works great.
Sent from Droid Ultra
2014 Puma 30-DBSS
2014 Ram 2500 Mega Cab 6.4L
cyclepuck is offline   Reply With Quote
Old 03-19-2014, 10:07 PM   #4
WFD
Is that Turtle Wax Wash n Dry just a car wash soap you mix in the water?
Rick
Old 03-20-2014, 04:40 AM   #5
Missing Link
cyclepuck's Avatar
Wash and dry is a soap but they also make a product called wax and dry. Spray it on a wet vehicle and dry with towel. Like a spray on wax but helps the drying process a lot.
2014 Puma 30-DBSS
Old 03-20-2014, 07:02 AM   #6
I've never polished my last camper since it had the metal siding but I washed it with rolloff boat wash from marine store. Works amazing with one of those extended brushes. Awning is clean and black streaks are gone and it shines like new.
Riva1 is offline   Reply With Quote
Old 01-04-2015, 10:12 AM   #7
DaveNTx's Avatar
I have a Puma 30KFB (model year 2013, mfg date 05/30/2012). Lots of decals or appliques' all over the outside; does wax cause these to oxidize & fade?
Also, is the corrugated siding on these Pumas made of aluminum or is it vinyl? I think the front is aluminum. I can't tell for sure.
2013 Puma 30KFB
2013 F250, 6.2L, 4x4
DaveNTx is offline   Reply With Quote
Old 01-04-2015, 08:42 PM   #8
Missing Link
cyclepuck's Avatar
Was will not hurt the decals and the siding is aluminum.
2014 Puma 30-DBSS
puma, wax
