Old 05-10-2015, 07:43 PM   #1
Puma slideout adjustment
Hi guys,
I'm after some advise on how to adjust my slide on at 2013 Puma 259rbss. I am in Ireland so I can't just call into my local RV dealer to have this done. The slide is not going out far enough on one side at the bottom. It's going out fine on the side the stop can it fitted to. I appreciate you will probably need more so just reply and I'll try to answer as best I can.
thanks
Will
will2020 is offline   Reply With Quote
Old 05-10-2015, 08:57 PM   #2
Cyber Phrenologist
Radio's Avatar
Knowing nothing about Puma, or even recently built RVs, have a read here:
Bummed out: Slide room out of alignment...
That's my journey through slide room adjustment!!
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 05-10-2015, 09:02 PM   #3
Dave_Monica's Avatar
You have an electric through the frame slide on your camper. Here's a link to the LCI manual, the adjustments are covered... http://lci1.com/assets/content/suppo...ideout-web.pdf
Dave
Old 05-10-2015, 09:10 PM   #4
Dave
Hi Dave thanks for that, sorry for being thick but if the slide is already tight on the side the actuator is on do I adjust this side in roughly back in the same amount as the other so when I send the side out they both will go out the full amount?
Old 05-11-2015, 08:38 AM   #5
If the slide is already tight on the actuator end you need to adjust the opposite side slotted bolts to make it the same. See figure 6 on page 10. There'll be slotted bolts on the top of the tube on the non-actuator side.
Dave
Old 05-11-2015, 01:38 PM   #6
Dave
thanks Dave I'll give this a go.
puma, slide, slide out
