Old 02-16-2013, 09:18 PM   #11
Not-so-Junior Member
VenturaBill's Avatar
Originally Posted by syencer View Post
I am guessing mine doesnt have this as both of my pipes are about 6 inches apart in the center of the roof just behind the front AC unit. Mine was made in August I think..
I know the two pipes you are referring to. Here's another photo showing all of the vent pipes on my 295RL, a total of 4.
There should be three to vent the waste tanks; black, galley and bathroom. So I would assume the 4th one on mine, just in front of the skylight, would be the conduit for wiring, etc.
That black pipe goes all the way to the storage compartment not far from the docking station and has a black plug on the bottom. I thought it might be some kind of drain but I will check it out tomorrow and post the results.
How is it one careless match can start a forest fire, but it takes a whole box to start a campfire?
2012 F250 6.7L Lariat 4x4 long bed
2013 Columbus 295RL
1952 Blonde Nurse
VenturaBill is offline   Reply With Quote
Old 02-16-2013, 09:37 PM   #12
SYE
SYE's Avatar
I only remember the 2 I will look tomorrow while I am taking stuff out if it.
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 12 Nights Camped 2018 57 nights reserved
SYE is offline   Reply With Quote
Old 02-17-2013, 12:16 PM   #13
OK - I researched it this morning and took photos... on our 295RL which was manufactured 1/16/13 we do have a conduit running from the roof to the basement near the docking station.
On the roof it looks like a waste tank vent and in the basement it looks like a plumbing clean-out plug.
I've posted pictures and arrows here to point it out...
Name:	Roof conduit.jpg
2013 Columbus 295RL
1952 Blonde Nurse
Old 02-17-2013, 01:50 PM   #14
SYE
SYE's Avatar
I was up there today and I only have the 2 in the center, I do not have 4. I looked and I also do not have the pipe in the basement either. I guess mine was built in early August so it doesn't have it.
Scott & Vicki
Old 02-17-2013, 02:34 PM   #15
Scott - A while back you suggested running wires through the power vent in the bathroom. I checked that out and it is a great alternative since you can run the wires right down through the closet to the controls area, and then there's a direct shot through the basement to the batteries in the front for solar, or in other directions for other devices you might install.
2013 Columbus 295RL
1952 Blonde Nurse
320rs
