Old 05-19-2016, 09:02 PM   #1
radio stinks ion ck142 any fixes on radio and tv
any fixes for the tv and radio signal
w0clf is offline   Reply With Quote
Old 05-20-2016, 03:34 PM   #2
Radio stinks
Not enough info...
Okie
Okie
Retired USMC&FAA
2015 Columbus 381FL
08 F450
USMC Okie is offline   Reply With Quote
Old 05-20-2016, 03:42 PM   #3
Flybob's Avatar
What antenna? Is amp button on? What radio?
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-20-2016, 06:57 PM   #4
Originally Posted by USMC Okie View Post
Not enough info...
Okie
the singal is really week to the radio and also tv if i hook out door ant on a tripod get ten times better signal than with equipment mounted ant on traileer something not right
Old 05-20-2016, 07:01 PM   #5
RSchleder's Avatar
W0clf-----Did you somehow miss these questions??? If it's too much effort to answer a few questions and provide enough info , it's probably going to be doubtful if you'll get the help you apparently need!
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 05-20-2016, 07:14 PM   #6
sorry the question from second response did not show on the phone. Yes the Have tried with booster on and off check connections behind the wall and the radio ant i am not seeing one on roof but see cble hooked to back of radio the tv ant is the basic bat wing on roof but does not seem to be receiving signal even tried to hook a external ant to out side hookup but on getting a good signal but run a cable out the door to same external ant get great signal. .
Old 05-21-2016, 04:56 PM   #7
Radio stinks
The batwing ant. has an amplifier built into it. it gets it's power through the ant. wire so he power must be on all the time. Check the connection to the ant,make sure it is good. One other thing to check is the wall connection for the cable to the TV. It is possible that they are marked wrong as was the one in my rig. The radio will have a ant. connection on the back of it. In most cases it is a single wire coming from it. Try to get it as high as you can Just pull it up and drape it on something. If it has an ant. connection outside as an Arial, check to see if it is connected. An ant. connection outside is not usual for a radio in a TT.
Okie
Okie
Retired USMC&FAA
2015 Columbus 381FL
08 F450
Old 05-21-2016, 09:29 PM   #8
found problem thanks for all the help
manufacture hook up the cables backwards finnally was able to get connectors out of wall. Thanks again all for the responces
radio
