Old 09-11-2015, 05:47 PM   #1
Rain spouts/run off
We purchased a 2016 Sabre 33ckts this year and had a question for others with similar model. We noticed on our last trip during a rain storm that the gutters on the left side of the entry door cause the area right in front of the door to get wet. Since the awning stops short of the slide (which it has to with the mounted wall arm) the gutter on the top of the awning rail shoots the water down between the slide in awning. I attached a picture with a red square around the gutter I am talking about.
Just wondering if anyone had a fix for that?
Gary
2015 Ford F350 FX4 SRW
2016 Sabre 33CKTS
16k Reese Titan Slider
40 gal ATI Transfer tank
Load Lifter 5000 Airbags
glraz is offline   Reply With Quote
Old 09-11-2015, 06:02 PM   #2
Fulltime family RVer
There's supposedly a trick with a rope. The water follows the rope to wherever you want it. Don't recall all of the details.
Old 09-11-2015, 07:55 PM   #3
Old car's Avatar
We have a 2015 model and we noticed that that particular spout would get caught in the awning arm when retracted. Sabre told me they didn't have a "short" version of the spout in the cream color. I took a pair of tin snips and cut it to clear the awning arm. I haven't noticed an issue with the water pouring down to cause an issue. Then again--if it's raining--I'm indoors!
Randy and Patty
2015 Sabre 33 CKTS-6 Platinum Edition
Reese 16K Slider hitch
2015 GMC Sierra 3500HD diesel dually
Old car is offline   Reply With Quote
Old 09-11-2015, 08:24 PM   #4
i agree if it is raining I am inside as well but sure makes it a mess right in front of the door. wondering if the gutter is level that if I put a dab of silicon in that end would it force it out the other end. Guess all I can do is try.
2016 Sabre 33CKTS
Old 09-11-2015, 08:36 PM   #5
Mr. Dan's Avatar
I have a spout that dumps on top of a slide WHICH LEAKS! When I think it's gonna rain, I stick a piece of plastic tubing on it, fasten it with a cable tie and hang the end of the tube off the top of the slide. You could use a longer tube and put the end under the trailer.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 09-11-2015, 08:39 PM   #6
iceblaze580's Avatar
I've used 1/2" clear tubing and shoved it over the end of the spout then put the other end where you want it
iceblaze580 is offline   Reply With Quote
Old 09-11-2015, 08:53 PM   #7
Who Dares, Wins
doc73's Avatar
Clothes pin and cotton clothes line tied to it, wicks the water along the pin them into the string.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is online now   Reply With Quote
Old 09-11-2015, 10:23 PM   #8
Thanks everyone for the ideas will give it a try when we head out in a couple weeks.
2016 Sabre 33CKTS
Old 09-12-2015, 12:26 PM   #9
TURBS's Avatar
What doc said
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "27 nights"
Old 09-12-2015, 12:55 PM   #10
Witch Doctor's Avatar
The real term is called a chain leader. I have installed many in my years of HVAC and sheetmetal. They do work down a chain, never hear of a rope. In fact at the SF museum in Goldengate park they are installed there or use to be.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
