Old 02-21-2018, 08:52 AM   #1
fifth wheelen's Avatar
Rear bumper capacity
Looking to install a platform on the rear bumper of a 2018 Columbus 340RKC 5th wheel to carry a 100 lb inverter/generator. Any thoughts appreciated.
fifth wheelen is offline   Reply With Quote
Old 02-21-2018, 08:54 AM   #2
a lot of threads on this topic. Some would say zero. Not meant to carry weight at all. Proper reinforcement is required. Also voids the warranty if its a new unit.
Kimber45 is offline   Reply With Quote
Old 02-21-2018, 03:39 PM   #3
Weekend Warrior
Greg Owen's Avatar
I'd say not, too. Looks like an aluminum extruded bumper. If it was a solid steel welded bumper (mine is), that would make a big difference.
Greg Owen is offline   Reply With Quote
Old 02-21-2018, 03:49 PM   #4
NMWildcat's Avatar
Looks like a thin steel bumper with an aluminum cover (rivets in the end). But either way, probably not strong enough to support over 100lbs bouncing down the road.
I take all my rigs to my favorite welding shop and have the rear bumper replaced with at least 1/8" steel 4x4. End caps will still fit. They also reinforce attachment to the frame and build a proper platform. Get estimates and I think you will be surprised at the affordable cost. And then you have no worries about strength
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
Old 02-21-2018, 03:59 PM   #5
Yes you can, you will want to purchase the platform that mounts to the bumper frame works ( the part of the bumper that bolts to the frame), I would also look at the camper frame to make sure it can support the weight. Alot of campers come with this type of platform.
Here is link to a picture of one. X2 on NMWildcat
https://www.google.com/search?q=fram...FHAYkqxev2VfM:
wildcatter is offline   Reply With Quote
Old 02-21-2018, 04:01 PM   #6
Broken Toe
Cowracer's Avatar
Carrying capacity of your bumper = one sewer hose.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
"Camper" 2016
Rockwood Signature Ultralite 8329ss
"Casper" 2017 Ram 2500 Laramie Diesel
..ProPride 3P Hitch - "Yeah. It's worth it."
Cowracer is offline   Reply With Quote
Old 02-22-2018, 07:29 AM   #7
Weekend Warrior
Greg Owen's Avatar
I believe you intended this to the OP--I know mine is fine!
Old 02-22-2018, 08:19 AM   #8
Tim
Hey now I have seen these bumpers also carry "Lots of Bumper Stickers" also! Youroo!!
Old 02-22-2018, 09:59 AM   #9
chevelleman's Avatar
Yeah I put a I put a metal box on the back on the bumper no proplem from New York to Florida I I have about 100 lb in it
chevelleman is offline   Reply With Quote
Old 02-22-2018, 10:01 AM   #10
Insert witty title here
My rear bumper has a sticker that says anything attacked to it will void the cassis warranty.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
timfromma is offline   Reply With Quote
Old 02-22-2018, 10:06 AM   #11
Everybody and their mother put the boxes on the back they also sell a bigger plastic box to if you wanted gold plastic box
Old 02-22-2018, 10:19 AM   #12
ben31's Avatar
Talk to or email Forest River to see if they sell an add-on rack. If they don't I know Lippert sells one that looks like it would fit. Using one of these isn't supposed to void your warranty.
I talked to Lippert and the one they sell doesn't fit my trailer (not enough space between the bumper and box).
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2016 Ram 3500 Laramie 4X4 6.7 Cummins Diesel
Never Enough Time Camping!!
ben31 is offline   Reply With Quote
Old 03-02-2018, 01:26 PM   #13
I just purchased my 5th wheel. While at the dealer there was a Palomino 298RL with a "Factory Rack" attached to the frame/rear bumper. I would recommend talking to the dealer about this option. The unit I say was at Richardson RV in Menifee CA
Pat K is offline   Reply With Quote
