Old 02-21-2018, 08:52 AM   #1
fifth wheelen's Avatar
Rear bumper capacity
Looking to install a platform on the rear bumper of a 2018 Columbus 340RKC 5th wheel to carry a 100 lb inverter/generator. Any thoughts appreciated.
fifth wheelen is offline   Reply With Quote
Old 02-21-2018, 08:54 AM   #2
a lot of threads on this topic. Some would say zero. Not meant to carry weight at all. Proper reinforcement is required. Also voids the warranty if its a new unit.
Kimber45 is offline   Reply With Quote
Old 02-21-2018, 03:39 PM   #3
Weekend Warrior
Greg Owen's Avatar
I'd say not, too. Looks like an aluminum extruded bumper. If it was a solid steel welded bumper (mine is), that would make a big difference.
Greg Owen is offline   Reply With Quote
Old 02-21-2018, 03:49 PM   #4
NMWildcat's Avatar
Looks like a thin steel bumper with an aluminum cover (rivets in the end). But either way, probably not strong enough to support over 100lbs bouncing down the road.
I take all my rigs to my favorite welding shop and have the rear bumper replaced with at least 1/8" steel 4x4. End caps will still fit. They also reinforce attachment to the frame and build a proper platform. Get estimates and I think you will be surprised at the affordable cost. And then you have no worries about strength
Scott and Liz - Southern NM
Old 02-21-2018, 03:59 PM   #5
Yes you can, you will want to purchase the platform that mounts to the bumper frame works ( the part of the bumper that bolts to the frame), I would also look at the camper frame to make sure it can support the weight. Alot of campers come with this type of platform.
Here is link to a picture of one. X2 on NMWildcat
https://www.google.com/search?q=fram...FHAYkqxev2VfM:
wildcatter is offline   Reply With Quote
Old 02-21-2018, 04:01 PM   #6
Broken Toe
Cowracer's Avatar
Carrying capacity of your bumper = one sewer hose.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
2016
Rockwood Signature Ultralite 8329ss
Rallies Attended:
Cowracer is offline   Reply With Quote
Old 02-22-2018, 07:29 AM   #7
Weekend Warrior
Greg Owen's Avatar
I believe you intended this to the OP--I know mine is fine!
Old 02-22-2018, 08:19 AM   #8
Tim
Hey now I have seen these bumpers also carry "Lots of Bumper Stickers" also! Youroo!!
Old 02-22-2018, 09:59 AM   #9
chevelleman's Avatar
Yeah I put a I put a metal box on the back on the bumper no proplem from New York to Florida I I have about 100 lb in it
chevelleman is offline   Reply With Quote
Old 02-22-2018, 10:01 AM   #10
Prime Member
My rear bumper has a sticker that says anything attacked to it will void the cassis warranty.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is online now   Reply With Quote
