Old 02-18-2014, 08:31 PM   #41
Doug, make sure to lube your wheel bearings. It took 2 tubes of grease in mine just to see it start coming around the front bearing
Mad DADDY is offline   Reply With Quote
Old 03-01-2014, 08:28 AM   #42
Carknocker Family
Ida Ratherbe Camping's Avatar
x2
I cant believe that they are not greased before leaving factory or dealership. I brought mine home 700 miles one way and after reading it on this forum. checked my axles. No grease and one didnt even have a zirc in it! Today is the first of March. Hope your caper showed up on time and your PDI goes well.
Nights camped 2015...20
Nights camped 2016...20
Nights camped 2017...24
2017 Ram 2500
2014 Salem 32BHDS
Ida Ratherbe Camping is offline   Reply With Quote
Old 03-04-2014, 07:53 AM   #43
TURBS's Avatar
Originally Posted by Ida Ratherbe Camping View Post
x2
These axles are assembled and greased from the axle manufacturer "ready to go" and the wheel bearings are just packed much like older car bearings whereas you pack the bearing and not the whole hub.
TURBS
Sabre owners united!
Old 03-04-2014, 12:26 PM   #44
TURBS
exactly no wheel bearing would last 700 miles without lube!
Of all the things I've lost in my life the thing I miss the most is my mind!
prairiecamper is offline   Reply With Quote
Old 03-22-2014, 10:27 PM   #45
SYE
SYE's Avatar
Originally Posted by Rmk2001800 View Post
Has anyone added a hitch to pull their boat or small trailer behind their columbus?? Is of can you post picture of how you mounted the additional hitch.
Mike
Mike or anyone else that knows,
As you were building your hitch for the Columbus, what was the measurement from Frame to Frame??
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
SYE is offline   Reply With Quote
Old 03-23-2014, 07:18 AM   #46
Rmk2001800's Avatar
66.5" inside the bumper support tubes
I had went to the dealer and measured a stock unit when i had built mine.
Mike
Rmk2001800 is offline   Reply With Quote
Old 03-23-2014, 07:27 AM   #47
Rmk2001800's Avatar
Name:	ImageUploadedByForest River Forums1395577594.122641.jpg
ID:	48211Click image for larger version
Name:	ImageUploadedByForest River Forums1395577609.274412.jpg
ID:	48212Click image for larger version
Name:	ImageUploadedByForest River Forums1395577623.852565.jpg
ID:	48213Click image for larger version
Name:	ImageUploadedByForest River Forums1395577646.860999.jpg
Old 03-23-2014, 08:51 AM   #48
SYE
SYE's Avatar
Thanks for the measurement, this is what I was looking at getting since I do not have a machine shop to make one.
CURT Manufacturing - CURT RV Trailer Hitch #13703 | CURT Manufacturing
Scott & Vicki
2021 4 reserved
Old 03-23-2014, 09:43 AM   #49
Rmk2001800's Avatar
There is no one in the area that can make one? I'm sure it will be half the price..
2- 2" 1/4 wall sq tubes- 66" long
2- 4" 1/4 12" flat stock
2 2"x 18" 1/16 thick sheet metal
1 curt reviever tube 24"-
Drill 6 holes
Couple welds
Old 03-23-2014, 09:55 AM   #50
Originally Posted by youroo View Post
Is towing (2) things (Triple Towing)? Youroo!!
triple towing is the correct terminology , why but when I talked to several states out west they even called it triple towing. which confused the #$%^#$ outa me at first because I pull doubles for a living.
linehaul is offline   Reply With Quote
Old 03-23-2014, 04:11 PM   #51
SYE
SYE's Avatar
In Michigan you have to have a Recreational Double Endorsement non you license so I refer to it as that.
Scott & Vicki
2021 4 reserved
Old 03-23-2014, 04:13 PM   #52
SYE
SYE's Avatar
Drill 6 holes
Couple welds
The cheapest of the 2 quotes that I received were 700.00, I wish I knew people around here with welders.
Scott & Vicki
2021 4 reserved
Old 03-23-2014, 04:15 PM   #53
Ford Idaho's Avatar
Any special requirements or do you just need to pay the bucks?
Old 03-23-2014, 04:28 PM   #54
SYE
SYE's Avatar
A few but simple, just pay for the endorsement and pass the test, I think it is an extra 10 bucks. There are a few requirements on the towing you can read about them here
http://www.michigan.gov/documents/re...le_21025_7.pdf
Scott & Vicki
2021 4 reserved
Old 03-23-2014, 04:41 PM   #55
Ford Idaho's Avatar
Thank You for the link.
The hitch used to tow the second trailer must
be attached to the frame of the fifth-wheel trailer.
Safety chains for the second trailer must be securely
attached at the extreme outer edge of the fifth-wheel
trailer with a locking mechanism.
Looks like the tough part to meet.
Old 03-23-2014, 04:57 PM   #56
SYE
SYE's Avatar
Not really, just have something welded or bolted to the outside frame ends because that is the most stable part, I had loops welded on my last 5er and they worked well
Scott & Vicki
2021 4 reserved
Old 06-09-2014, 08:23 PM   #57
SYE
SYE's Avatar
I finally got my rear hitch installed last weekend, now I have to wire it up.
Scott & Vicki
2021 4 reserved
columbus, hitch
