Old 08-06-2015, 03:56 AM   #1
recommend sealant Puma
Hi,
What product do you guys recommend to replace the original sealant used on my Puma? just noticed where the sides meet the front the joint the sealant is getting a little tired.
will2020 is offline   Reply With Quote
Old 08-06-2015, 04:39 AM   #2
Dicor non-leveling caulk. $10.00 per tube at CW.
harderd is offline   Reply With Quote
Old 08-06-2015, 04:56 AM   #3
I have tried using this but it is very messy unless you get the exact amount you need, if you touch it then it goes stringy and ends up everywhere.
Old 08-06-2015, 05:04 PM   #4
It is messy but it it the best stuff you can use. Silicone won't last and then nothing else will stick where it was. Use painters tape and tape off both sides then run a light bead and smooth it with your finger. Let it dry and pull off the tape.
Old 08-06-2015, 05:32 PM   #5
Canadian Member
itat's Avatar
I've had good results with ProFlex RV Sealant
All RV Aftermarket Products : Pro Flex RV Flexible Sealant
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
puma
