Old 05-16-2014, 06:34 PM   #1
daverain's Avatar
Question Reefer ills
Hi All,
Have a dometic refrig. problem that I know someone will have a answer for...(I hope)..
Seems our Dometic on our 2011 sabre freezes real well, will go down to 2 degrees, but refer section only 40 42. So, here's what I've done so far. Disconnect the thermister, refer drops to 29f. Bought a snip the tip thermister thinking the old one didn't ohm out well. No change, 42f.Currently running on electric, did not try gas yet, but seems ok since I did remove the thermister plug off the board and the temp dropped. Installed a pair of fans on the reefer fins,last season, no change. Installed a fan in the back of the unit to bring ambient air into the unit, no change.Did the dollar bill thing on the door gasket, o.k. Now wondering if there is some sort of default temp built in on the board? Going to run it on gas tomorrow and see how it does. Problem is 42 isnt low enough when we go down south, open the door a couple of times, the temp will soar up to 48 50. The ambient up here in new jersey has been around 70 so should be cooling well and the trailer is level.
ANY SUGGESTIONS??
Thanks,
Dave and Rainy
daverain is offline   Reply With Quote
Old 05-20-2014, 01:12 PM   #2
Have you slid the thermistor up the fin toward the freezer as far as it will go and checked the cooling temp?
CityMan is offline   Reply With Quote
Old 05-20-2014, 01:18 PM   #3
TURBS's Avatar
He's removed the thermistor and replaced with "snip the tip"
http://snip-the-tip.com/cgi-bin/articca.cgi
TURBS
"Sabre owners united"
Old 05-21-2014, 09:59 AM   #4
Sorry I did not know what snip the tip was!
Old 05-21-2014, 10:16 AM   #5
TURBS's Avatar
I bet you do now! Lol
TURBS
Old 05-21-2014, 04:29 PM   #6
Perhaps Daverain would prefer to speak for himself...
2009 Rockwood 2701SS
2008 Tundra Crewmax 5.7
bob7794 is offline   Reply With Quote
Old 05-21-2014, 04:49 PM   #7
VinceU's Avatar
Originally Posted by daverain View Post
Hi All,
ANY SUGGESTIONS??
Thanks,
Dave and Rainy
Easy one, you have poor door gasket on the frig box. That would be together with a lot of frost build up.
Worse is really sounds like a partially plugged tubing feeding refrigerant to the refrig section. Freezer getting plenty of refrigerant, main box not so much. I've seen where the coils (black tubing in the back) are gently tapped
and free up the sentiment trapped in the small diameter tubing. Free and worth a try. Look for the lower set of tubing feeding the frig vs the upper set serving the freezer.
Old 05-21-2014, 05:07 PM   #8
mark0224's Avatar
what is the proper temp in the freezer ? and the refer? My wife claims refer doesn't seem cold enough yet it has a temp of 40 deg and freezer is 32 deg.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 05-21-2014, 05:25 PM   #9
TURBS's Avatar
TURBS
Old 05-21-2014, 05:33 PM   #10
AquaMan's Avatar
You lost me on this comment....
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
