Old 01-30-2013, 01:07 PM   #11
TURBS's Avatar
Red wires are from fans to show you my "switched power source"
Old 01-30-2013, 01:09 PM   #12
TURBS's Avatar
90 degree day with all the humidity you could handle.
Fridge was on 8 hours.
Old 01-31-2013, 10:38 AM   #13
Originally Posted by RoadTrip View Post
Turbs - where'd you get that middle one (on the inside). I've been looking for a battery operated little fan for inside - I read that it helps even out the coolness and allows the fridge to cycle less.
Most Radio Shacks stock these kinds of 12VDC cooling fans in a variety of sizes.
You can also get these kinds of units designed for supplemental Laptop cooling.
Cathy & Jeff
Midland, Michigan
2013 Sabre 32RCTS / 2012 Ram2500 Hemi
SimchaSabre is offline   Reply With Quote
Old 01-31-2013, 12:18 PM   #14
Here's one for ya and do a search on this sight... lots of great ideas.
Dual Cooling Fan 3.5 inchPC Hard Disk Drive HDD Cooler Fan The 3.5 inch PC Hard Drive Cooler connects via a standard PSU 4 pin internal power connection as a self-power mode, no power adapter required
grayfox is offline   Reply With Quote
Old 01-31-2013, 03:01 PM   #15
amxpress's Avatar
There was a problem with the fan being noisy when the fridge was on but it has been taken care of on later models. It created a high frequency whine that could be heard when sitting or in the kitchen. Adding an auxiliary fan is an idea especially when on high temperatures.
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
amxpress is offline   Reply With Quote
Old 01-31-2013, 05:49 PM   #16
That the same problem many had. The computer fans are very quite, many on this site have used them. They help with the cooling also.
Old 01-31-2013, 05:52 PM   #17
TURBS's Avatar
I even stuck an additional one in my converter to help keep it cool.
With a manual switch of course.
Old 01-31-2013, 05:56 PM   #18
I like he thermometer in the fridge. I've never done that for some reason...
Good idea.
Old 01-31-2013, 06:02 PM   #19
TURBS's Avatar
Good idea.
It's nice to know RIGHT where your at!
Old 01-31-2013, 08:45 PM   #20
Turbs, I'm impressed my man, nice job. To be honest, I never really saw a need to add fans to the frig, but then again I have not ever had an issue with it. I can see where this would eliminate any chance of that happening. Thanks for the info.
Dave and Kim
Charlie and Ripken (4 Leggers)
2012 GMC Sierra Denali 2500 6.6L Diesel
2013 Columbus 320RS
Maryland
Times camping in 2013 - 5
Sporoo is offline   Reply With Quote
fan
