Old 02-11-2013, 05:09 PM   #41
Ok, 2013 Columbus and i checked mine today....... no baffle. it's a open cavity above the top of the frig. I'm going to make a baffle up using thin sheet metal.
Paul & Beth
Sandusky, Ohio
2013 Columbus 320RS
2009 Silverado 2500HD
drinkh20 is offline   Reply With Quote
Old 02-11-2013, 08:06 PM   #42
This has been a very informative thread so, thanks to all who have contributed.
It's nice that so many people can come together and find the answers.
grayfox is offline   Reply With Quote
Old 02-12-2013, 12:32 PM   #43
VinceU's Avatar
Originally Posted by grayfox
My Prime Time Crusader 320 RLT has the "Baffle" in the top of the frig. . It is made out of a thin piece of scrap plywood. I've never had a problem with the performance of my frig. in the hottest weather... works perfect. I do have a high pitched noise problem with the fan, absolutely annoying no doubt about it. I'll replace the fan this spring with a computer fan.
Just realize that fan has mucho more flow rate than a typical axial fan used in computers. Look in GT threads for data.
Old 02-12-2013, 12:57 PM   #44
Thanks for the heads up. I'll check it out. Some here have replaced the fan with a double fan set up. Maybe your onto something. I've not had any trouble with cooling even in the hottest weather. I just want to get rid of the high pitched noise.
Just another thought, I don't believe flow rate has ever come up. Maybe Herk or one of the other Info Nerds can chime in. Just making a little fun of our friends on the forum.
Old 02-12-2013, 01:12 PM   #45
TURBS's Avatar
You can get various cfm computer fans there not all the same.
Old 02-12-2013, 03:53 PM   #46
Thanks, Turbs do you have a recommendations in terms of flow rate?
Old 02-12-2013, 03:58 PM   #47
TURBS's Avatar
I'd have to look at mine.
Less cfm quieter.
More cfm louder .
Old 02-12-2013, 04:18 PM   #48
I'll have to check and see whats required. I just want to get rid of that damn high pitched noise without hurting the performance of the frig.
Old 02-12-2013, 05:37 PM   #49
AquaMan's Avatar
Sometimes the way it is mounted can amplify the sound. Take a look at the existing fan and see if you can mount it between some rubber washers to isolate any vibration. It's a long shot, but may work.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 02-12-2013, 05:45 PM   #50
Tried to remount with no change. It's in the fan,but I appreciate thought.
fan
