Old 01-30-2013, 12:50 PM   #1
Refrigerator Fan
I have a 320rs with the 8 cubic ft refrigerator. I was just reading my latest highways magazine and there was a question in it concerning a noisy refrigerator fan. I didn't know that there was a fan. I never hear any kind of fan. Where is it? Also they talked about adding an additional fan to vent the hot air. We camp in some very hot places and since the frig is in the slide, I would like to enhance the cooling anyway I can. Would someone out there please enlighten me.
travelor2 is offline   Reply With Quote
Old 01-30-2013, 01:03 PM   #2
TURBS's Avatar
You may not have a fan at all.
Ill post pics of my fans I installed
Turbs
Old 01-30-2013, 01:05 PM   #3
TURBS's Avatar
First one and last one are on outside of fridge in the access panel .
Other is inside to circulate the air.
Old 01-30-2013, 01:46 PM   #4
Graduate Member
RoadTrip's Avatar
Turbs - where'd you get that middle one (on the inside). I've been looking for a battery operated little fan for inside - I read that it helps even out the coolness and allows the fridge to cycle less.
--2009 Sunseeker 2860DS (Class C)
- one Hotwife, and two boys under 2(with one on the way!)
2013 - 53 days
2012 - 26 days
RoadTrip is offline   Reply With Quote
Old 01-30-2013, 01:51 PM   #5
TURBS's Avatar
I bought it from best buy online.
Its 12v and runs whenever fridge is turned on.
Its hooked to the power supply for fridge oe light.
Old 01-30-2013, 01:52 PM   #6
Graduate Member
RoadTrip's Avatar
thanks
2013 - 53 days
2012 - 26 days
Old 01-30-2013, 02:01 PM   #7
Thanks for the pictures. So, the 2 outside fans are venting hot air from the frig compartment. Where are they venting the air? I assume that these fans are 12V as well. Are they on a thermostat or do they run all the time or is there a switch. Did you notice a difference in the refrig temp when they are running?
Old 01-30-2013, 02:01 PM   #8
TURBS's Avatar
thanks
No problem.
I mounted it by sticking two stove bolts through mounting flange of fan and the soldering an alligator clip on each one .
Then I just clip it on the fins .
Turbs
Old 01-30-2013, 02:03 PM   #9
TURBS's Avatar
The two outside fans blow hot air up the vent stack that comes out the roof.
They also only work if fridge is turned on.
But I installed a rocker switch to turn them off manually if its cooler outside.
Old 01-30-2013, 02:07 PM   #10
Two ideas, not that I know where your fan is or if you have one.
While in the Tropics on our sailboat we used reflective insulation as a sun-shield. Although the refer was insulated heavily--built properly-- the insulation hung over the side made a significant difference. At times, we used the insulation for our windows even though they were bronze coated and reflective. Anything helped.
Today, our RV is sometimes enhanced by this sheeting on the inside of our windows which makes a huge difference in the 5w temp. You'll be able to feel the difference no matter the curtain style. And in Alaska this insulation blocked that 22+ hours of light in our bedroom. If it's hot inside the cabin your refer will work harder.
However, since we've got some space between the refer and the RV outside wall, with a bit of work this reflective insulation was added. I'm uncertain if we could measure the difference since it was done on day one, but it is bound to help while staying put in AZ, TX, etc, especially if the sun is on that side.
BTW, there are several model fans which are sold to mount between the wall and refer, exhausting hot air, but they take power.
Finally, we've always used a small 3v fan inside the refer to circulate the air. Measurements of the refer confirmed it's worth.
A product from Home Depot, Model # BP24010 Store SKU # 184928, might give you some ideas.
Mike
traveler2955 is offline   Reply With Quote
Old 01-30-2013, 02:07 PM   #11
TURBS's Avatar
Red wires are from fans to show you my "switched power source"
Old 01-30-2013, 02:09 PM   #12
TURBS's Avatar
90 degree day with all the humidity you could handle.
Fridge was on 8 hours.
Old 01-31-2013, 11:38 AM   #13
Most Radio Shacks stock these kinds of 12VDC cooling fans in a variety of sizes.
You can also get these kinds of units designed for supplemental Laptop cooling.
Cathy & Jeff
Midland, Michigan
2020 Cedar Creek 34IK / 2019 Ram3500 CID
SimchaSabre is offline   Reply With Quote
Old 01-31-2013, 01:18 PM   #14
Here's one for ya and do a search on this sight... lots of great ideas.
Dual Cooling Fan 3.5 inchPC Hard Disk Drive HDD Cooler Fan The 3.5 inch PC Hard Drive Cooler connects via a standard PSU 4 pin internal power connection as a self-power mode, no power adapter required
grayfox is offline   Reply With Quote
Old 01-31-2013, 04:01 PM   #15
amxpress's Avatar
There was a problem with the fan being noisy when the fridge was on but it has been taken care of on later models. It created a high frequency whine that could be heard when sitting or in the kitchen. Adding an auxiliary fan is an idea especially when on high temperatures.
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
amxpress is offline   Reply With Quote
Old 01-31-2013, 06:49 PM   #16
That the same problem many had. The computer fans are very quite, many on this site have used them. They help with the cooling also.
Old 01-31-2013, 06:52 PM   #17
TURBS's Avatar
I even stuck an additional one in my converter to help keep it cool.
With a manual switch of course.
Old 01-31-2013, 06:56 PM   #18
I like he thermometer in the fridge. I've never done that for some reason...
Good idea.
Old 01-31-2013, 07:02 PM   #19
TURBS's Avatar
Good idea.
It's nice to know RIGHT where your at!
Old 01-31-2013, 09:45 PM   #20
Turbs, I'm impressed my man, nice job. To be honest, I never really saw a need to add fans to the frig, but then again I have not ever had an issue with it. I can see where this would eliminate any chance of that happening. Thanks for the info.
Dave and Kim
Charlie and Ripken (4 Leggers)
2012 GMC Sierra Denali 2500 6.6L Diesel
2013 Columbus 320RS
Maryland
Times camping in 2013 - 5
Sporoo is offline   Reply With Quote
fan
