Old 05-19-2013, 07:09 PM   #1
treaves's Avatar
Remove AC vent?
I see a big piece of Styrofoam in the vent. What is the correct way to remove the circular grill? Does it just pry/pop out? I have a real bad habit of breaking things if I do not know exactly how to do it.
2012 Ram 2500 Laramie Limited CCLB CTD
2014 Columbus 320RS
treaves is offline   Reply With Quote
Old 05-19-2013, 07:12 PM   #2
TURBS's Avatar
They "snap" off ..... but they don't come off easy.
Atleast mine didn't.
Shouldn't be foam in there tho....
Pics?
Old 05-19-2013, 07:21 PM   #3
QCCowboy's Avatar
I use an angled screwdriver to get under the lip of the vent which allows me to pry it a little and it pops right off.
Jack of all trades - Master of none
2012 F350 CC DRW - 6.7L PSD
2014 Sabre 36QBOK
QCCowboy is offline   Reply With Quote
Old 05-19-2013, 08:40 PM   #4
amxpress's Avatar
Use a plastic trim tool to pry off the vent. Your local auto parts store should have them.
They look like this:4 Piece Trim Molding Door Panel Removal Tool Kit , Plastic Pry Tools on eBay!
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
amxpress is offline   Reply With Quote
Old 05-19-2013, 09:02 PM   #5
rip
rip's Avatar
I had to remove a small piece of foam from mine too. It wasn't like the smaller stuff, and it hung at the vent. I used a pair of needle nose pliers to break it up and pull it out the circle vent.
My trailer still snows the little stuff each trip this first four months. Most comes from the ducted vents, although I sometimes see some behind the A/V cabinet. Seems less each time.
I thought cleaning up the sprinkles of white styrofoam beads was part of breaking in a new trailer, no?!
Ray
+ 2013 Rockwood Windjammer 2809W
+ 2008 GMC Sierra Crew Z71
+ 2002 Ford F-250 7.3L 4X4
rip is offline   Reply With Quote
Old 05-20-2013, 01:52 PM   #6
I noticed when I looked into the bathroom vent I seen what looked like stryrofoam lining the top of the vent. I thought it was strange to have insulation on the inside of the vent.
It looks like it belongs there. So you are saying it doesn't?
2013 Columbus 295RL Fifth Wheel
2011 Ford F-250 Diesel 4x4 CC KR
Tim295 is offline   Reply With Quote
Old 05-20-2013, 02:02 PM   #7
treaves's Avatar
I'll post a picture once I get home and can take one. On one of my living room vents, you can see a hunk of Styrofoam sitting on top of the vent. A chuck of it.
2014 Columbus 320RS
Old 05-20-2013, 07:21 PM   #8
rip
rip's Avatar
Nope, not saying that at all.
In the ducted air on my trailer model, it "looks like" they simply put tunnels in the roof insulation to act as ducts to the round vents for my air flow, then didn't completely coat or line those tunnels in the styrofoam-like insulation so that bits and pieces won't flake off and blow out.
If that's the case, I suspect they may use that kind of cost effective short-cut on other ducted air models too.
The result on my trailer model is "snowing" of the styrofoam-like beads from the ducts and occasional flaked-off chunks appearing. Not a lot, just enough to notice some here and there each trip. Figure it will stop after a while, just a break-in thing.
I thought this initial "snow" effect (attached a sample pic) would be common with the duct design I'm seeing. Maybe I'm the only one experiencing this?
Ray
Old 05-20-2013, 07:46 PM   #9
iceblaze580's Avatar
I have several huge chunks in the vents of my 325rl it's a design flaw of the a/c system
iceblaze580 is offline   Reply With Quote
Old 05-20-2013, 10:00 PM   #10
Send a message via ICQ to ByronCR Send a message via AIM to ByronCR Send a message via MSN to ByronCR Send a message via Yahoo to ByronCR Send a message via Skype™ to ByronCR
I had several large chunks in my AC vents as well. I actually went through on my PDI and just popped all the covers off while the AC was running and stuck my hand up in there to check for other loose chunks. Had the dealer come in and clean up the mess after I was done.
Byron R
2013 Columbus 295RL
2006 F350 6.0L Crew Cab LB SRW
ByronCR is offline   Reply With Quote
