Old 08-11-2017, 07:07 AM   #1
Removing paint from dealer
On the tongue of our trailer the dealer painted numbers on there...when we first picked it up I seen them but figured it was just a grease pencil or something similar and easily removable...months later and several washes it's still there...any ideas on removing it?
Tow Vehicle
2013 F150 FX4 5.0 SuperCrew
Travel Trailer
2015 Solaire 317BHSK Texas Edition
Jason_WVU is offline   Reply With Quote
Old 08-11-2017, 07:16 AM   #2
I have it on mine too. Haven't really thought about removing it. I would guess just get a can of Krylon and cover it. Now I think I'll probably do that, not a big deal but I have black paint at the house already.
Dwayne and Susan
Jiro and Phoebe-4 legged family members
Mike and Dana - Traveling buddies
2016 Ford F350 XLT 6.7 Powerstroke DRW 4X4
2016 Brookstone 395RL
dwayneb236 is offline   Reply With Quote
Old 08-11-2017, 07:21 AM   #3
Semperfi24's Avatar
You could try WD40, that seems to work pretty well for taking things off. Or you could just spray paint over it with some black paint?
_________________________
2018 Rockwood Mini Lite 2504S
2018 Ford F150 Lariat Special Edition 3.5 Ecoboost
Semperfi24 is online now   Reply With Quote
Old 08-11-2017, 05:29 PM   #4
I should have stated in my post that I tried a little bit of paint to cover it up...problem is you can still see the outline of the numbers
Tow Vehicle
Travel Trailer
Old 08-11-2017, 08:30 PM   #5
Head Rambler
Sand it smooth well and then paint over it. You may have to sand and spray a few times to get it covered well.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 08-12-2017, 01:29 PM   #6
DouglasReid's Avatar
Then sand the paint off and repaint or simply use another coat and see if that does the trick.
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 08-12-2017, 01:47 PM   #7
Oaklevel's Avatar
The paint is not from the dealer it is from the factory. I never have worried about covering it up.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 08-12-2017, 10:28 PM   #8
rockfossilman's Avatar
My Rockwood had the word "SHOW" in the same place. A 10-second swipe with Rustoleum Satin Black spray paint covered it perfectly and the paint blended in perfectly with the rest of the tongue!
Rockfossilman - Western PA
Rockwood UL 2604ws - 2013 F150 w/MaxTow
"I'm a man, but I can change, if I have to. . .I guess."
Red Green
"Quando Omni Flunkus Moritati"
rockfossilman is offline   Reply With Quote
Old 08-13-2017, 09:33 AM   #9
I just painted over mine with Rustoleum black satin as well.
keith_h is offline   Reply With Quote
Old 08-13-2017, 03:17 PM   #10
I may be suggesting overkill here. If the trailer tongue is pretty rust free at this point, I would suggest using Rustoleum bed liner paint to do the entire tongue. It is available in the automotive department of Walmart. When we bought our Sunseeker, I did that on the hitch. Three years later, it still looked new and no rust. Also, if you have a backup camera on your TV, I would suggest painting the front 3" of the hitch at the ball mount with white paint. When backing up to align on the hitch, that white spot is so easy to see on the monitor. I first tried red, but it didn't have enough contrast.
PenJoe is offline   Reply With Quote
dealer
