Old 08-26-2018, 06:20 PM   #1
removing U shape dining area
So i have decided i dont like the U shaped dining area, im gonna replace it with 2 recliners and a end table in the middle and remount the plug that is there.
so my question is anyone else done this? looking to see what others have done.
i bought this off the lot so thats why im removing, if i was to order i would of ordered like that.
if anyone is interested in the removal stuff let me know
2018 Puma Unleashed 373 QSI Toy hauler Fifth wheel
Firedude26 is offline   Reply With Quote
Old 08-26-2018, 06:23 PM   #2
Rmk2001800's Avatar
I removed mine in the last camper- about 30 screws and 10 pcs and the recliners were getting installed. Great mod!
Rmk2001800 is offline   Reply With Quote
Old 08-26-2018, 07:10 PM   #3
JJaxon's Avatar
Pics of the dinette, size measurement, and location my help get them out of your garage.
John
2019 Ram 3500 CC 4X4 Cummins 6.7l
2020 Fuzion 369 toy hauler
JJaxon is offline   Reply With Quote
Old 08-26-2018, 07:11 PM   #4
ill measure tomm, but first off in in SE MI
Old 08-26-2018, 07:23 PM   #5
I removed the dinette from my SS2300 recently, not the U-Shaped one. If you type Remove/Exchange Dinette in the Search Bar, you will see plenty of threads on the topic...
Phil
PhilG is offline   Reply With Quote
Old 08-26-2018, 07:31 PM   #6
Someone just posted about doing this a few days ago. Go up to the search field and do a search.
2011 Traverse LT, 3.6L, FWD
Old 08-26-2018, 07:33 PM   #7
i did , it didnt show anything, sorry, sometimes the search dont always show everything, maybe i typed wrong thing in box,
Old 08-26-2018, 07:41 PM   #8
Here's one:
http://www.forestriverforums.com/for...cs-121842.html
Try this search:
https://www.google.com/search?q=remo...iverforums.com
Old 08-27-2018, 01:27 PM   #9
Removing U shaped dinette
We have a 270s where we removed the U shaped dinning table and benches. We installed side-by-side theater recliners, that my Wife found on Amazon (on sale)! This also has a central console where I installed a power outlet that also includes 2 USB ports. So running our laptops and charging our phone will be convenient.
Some things we checked before doing this work.
Important - I strongly recommend - disconnect the shore power and set the battery disconnect. If you need power, run an extension from a separate power source. Lot easier doing that then replacing fuses and/or the ATS
1.) Measure the space for width, length and depth
2.) Find a seating unit that you like and will fit in the dinette space.
3.) Since our dinette area is on the slide out, we go a weight measurement of what the dinette components (ours included a large table that had a center metal post pivot.
Compare that weight to the weight of the new seating unit. You don't want to add a lot of weight that may impact the slide operation.
4.) Before and during the dinette disassembly, take pictures. Even though we were not keeping the dining area components - pictures of how the wiring was laid out and attached help in the 'pre-install' of the new seating area.
5.) Take your time. Removing wood that is stabled with large connectors can snag clothing and skin.
To make sure I did not damage the walls/floor, I reused the same length screws - or if new ones were needed, matched the length. This prevented any accidents (holes through the exterior walls, etc.)
The above work took about 12 hours, working over 3 days, but this arrangement is more comfortable for us.
I've included a picture of the new seating area.
Best wishes -
Name:	New seating_v2a.jpg
rhutzler is offline   Reply With Quote
Old 08-27-2018, 04:20 PM   #10
I would also suggest: Measure your door and make sure any new seating you buy can fit through it!!!
Old 08-27-2018, 06:15 PM   #11
We replaced the u shaped dinette in our 25FKS Micro Lite with a triple recliner couch about 2 months after we bought it new. Best decision ever. Bought the couch from recpro.com. All of their furniture breaks down into pieces small enough to go through a standard RV door.
morganrc1955 is offline   Reply With Quote
Old 08-27-2018, 07:41 PM   #12
Raab's Avatar
We did exactly what you're referring to, except we also removed the couch from the slide. Moved the table to the corner where the couch was and bought 2 stools to sit on. We then put the recliners where the dinette was. My cousin built a 3 sided table to cover the outside access hatch and mounted it to the outside wall. Hubby put the outlet in the table and we are thrilled with the results.
Name:	camper chairs 1.jpg
Name:	camper chairs 2.jpg
2015 GMC Duramax
2014 Puma Unleashed 351THSS
2014 FJR1300
2014 CTX1300
Raab is offline   Reply With Quote
Old 08-27-2018, 07:55 PM   #13
Tigger1's Avatar
OP - not sure of your slide measurements, etc but we did this earlier in the year
http://www.forestriverforums.com/for...cs-153804.html
2010 Toyota Tundra DC SR5 5.7l 4x4
2020 Grand Design Imagine XLS 22MLE
Andersen WDH
2018 Rockwood Mini Lite 2104s
2014 Jayco x17z Hybrid
Tigger1 is offline   Reply With Quote
Old 09-03-2018, 08:49 AM   #14
Best wishes -
thats exactly what im gonna be adding, i have 100" so i can do a set up like that plus put end tables atg ea end, looks great!!!!
Old 09-03-2018, 09:01 AM   #15
i hAve a toyhauler with the patio doors inside so i have plenty of room, good point though
Old 09-03-2018, 01:39 PM   #16
ok i found a power love seat thats gonna fit real nice, even have room on each side for a small end table, i cant wait to do this, gonna be a few weeks though. Art Van had this for $600 today. i think its a steal.
Old 09-16-2018, 04:23 PM   #17
Well Removed the U shape seating today, all came out perfect. now for the install of the sofa.
Old 09-22-2018, 07:02 PM   #18
Finished ! love it, cant wait to use it now, lol stained and varnished the end tables i made today also.
not sure why one pic is sideways, sorry
ID:	187275   Click image for larger version
ID:	187276   Click image for larger version
ID:	187277   Click image for larger version
Old 02-14-2019, 08:40 PM   #19
Did you buy your power loveseat at a RV furniture dealer or just a regular loveseat?
DGLardon is offline   Reply With Quote
Old 02-15-2019, 06:30 AM   #20
bought it from Local Art Van store here in MI.
