Old 08-26-2018, 06:20 PM   #1
removing U shape dining area
So i have decided i dont like the U shaped dining area, im gonna replace it with 2 recliners and a end table in the middle and remount the plug that is there.
so my question is anyone else done this? looking to see what others have done.
i bought this off the lot so thats why im removing, if i was to order i would of ordered like that.
if anyone is interested in the removal stuff let me know
2018 Puma Unleashed 373 QSI Toy hauler Fifth wheel
Firedude26 is offline   Reply With Quote
Old 08-26-2018, 06:23 PM   #2
Rmk2001800's Avatar
I removed mine in the last camper- about 30 screws and 10 pcs and the recliners were getting installed. Great mod!
Rmk2001800 is offline   Reply With Quote
Old 08-26-2018, 07:10 PM   #3
JJaxon's Avatar
Pics of the dinette, size measurement, and location my help get them out of your garage.
John
2019 Ram 3500 CC 4X4 Cummins 6.7l
2018 Carbon 347 toy hauler
JJaxon is offline   Reply With Quote
Old 08-26-2018, 07:11 PM   #4
ill measure tomm, but first off in in SE MI
Old 08-26-2018, 07:23 PM   #5
I removed the dinette from my SS2300 recently, not the U-Shaped one. If you type Remove/Exchange Dinette in the Search Bar, you will see plenty of threads on the topic...
Phil
PhilG is offline   Reply With Quote
Old 08-26-2018, 07:31 PM   #6
Someone just posted about doing this a few days ago. Go up to the search field and do a search.
2011 Traverse LT, 3.6L, FWD
Old 08-26-2018, 07:33 PM   #7
i did , it didnt show anything, sorry, sometimes the search dont always show everything, maybe i typed wrong thing in box,
Old 08-26-2018, 07:41 PM   #8
Here's one:
Dinette to double recliner modification w/pics
Try this search:
https://www.google.com/search?q=remo...iverforums.com
Old 08-27-2018, 01:27 PM   #9
Removing U shaped dinette
We have a 270s where we removed the U shaped dinning table and benches. We installed side-by-side theater recliners, that my Wife found on Amazon (on sale)! This also has a central console where I installed a power outlet that also includes 2 USB ports. So running our laptops and charging our phone will be convenient.
Some things we checked before doing this work.
Important - I strongly recommend - disconnect the shore power and set the battery disconnect. If you need power, run an extension from a separate power source. Lot easier doing that then replacing fuses and/or the ATS
1.) Measure the space for width, length and depth
2.) Find a seating unit that you like and will fit in the dinette space.
3.) Since our dinette area is on the slide out, we go a weight measurement of what the dinette components (ours included a large table that had a center metal post pivot.
Compare that weight to the weight of the new seating unit. You don't want to add a lot of weight that may impact the slide operation.
4.) Before and during the dinette disassembly, take pictures. Even though we were not keeping the dining area components - pictures of how the wiring was laid out and attached help in the 'pre-install' of the new seating area.
5.) Take your time. Removing wood that is stabled with large connectors can snag clothing and skin.
To make sure I did not damage the walls/floor, I reused the same length screws - or if new ones were needed, matched the length. This prevented any accidents (holes through the exterior walls, etc.)
The above work took about 12 hours, working over 3 days, but this arrangement is more comfortable for us.
I've included a picture of the new seating area.
Best wishes -
Name:	New seating_v2a.jpg
rhutzler is offline   Reply With Quote
Old 08-27-2018, 04:20 PM   #10
I would also suggest: Measure your door and make sure any new seating you buy can fit through it!!!
