Old 04-15-2013, 07:16 PM   #1
SYE
SYE's Avatar
Roadmaster Active Suspension
I was just going too respond to the other posts about this but it would not let me as the were to old. So I started a new one. I bit the bullet and purchased this for my truck. I will say it was on of the simplest installs that I have done on my truck. It took less than an hour from start to finish. I have not drove it but I will on Wednesday when I pick up my 5er and I will provide another update after that. So I just want to share the pictures that were taken during the install. The first pic is of my truck backed up against the 5th wheel but not hooked up. The next one is with my truck hooked up and you can see the sag. The rest are of the installation. If you have any questions feel free to ask!!!
ID:	28073   Click image for larger version
ID:	28074   Click image for larger version
ID:	28075   Click image for larger version
ID:	28076   Click image for larger version
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 47 reserved
SYE is offline   Reply With Quote
Old 04-15-2013, 07:29 PM   #2
SYE
SYE's Avatar
More Pics
ID:	28078   Click image for larger version
ID:	28079   Click image for larger version
ID:	28080   Click image for larger version
ID:	28081   Click image for larger version
Scott & Vicki
Old 04-15-2013, 07:40 PM   #3
DDC
DDC's Avatar
Similar to adding an extra leaf to your springs although it does give you the convenience of removing them.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 04-15-2013, 07:45 PM   #4
SYE
SYE's Avatar
Yes it does, probably easier to remove than install. I am real interested to see how it rides. In case you do not know anything about them here is the link to their page
Roadmaster Active Suspension Kits | Helper Springs | Overload Springs
Scott & Vicki
Old 04-23-2013, 06:38 PM   #5
JoeMazz's Avatar
So @Syencer...How did it work out? I'm currently on the RAS/Airbag fence myself and would really like to hear how you did with the RAS...
JoeMazz is offline   Reply With Quote
Old 04-23-2013, 07:47 PM   #6
SYE
SYE's Avatar
Well I have only pulled my 5er once since I put them on and that was home from the dealership when I picked it up from repair. As for the ride it seems to be quite a bit smoother when pulling it kind of feels like it is floating. It pulled great before, but now even better. On rough roads it rides better as well the springs are absorbing all of the bumps now instead of the frame. I am pleased so far, I am actually taking it this weekend on a trip I can update again next week. So far I am impressed. the only thing I was hoping for was less sag, and there was, but not as much as I wanted.
Scott & Vicki
Old 04-23-2013, 08:05 PM   #7
JoeMazz's Avatar
Wow, still sags? What do you think your pin weight is? I tried to get specs from Roadmaster on it's capacity rating with no results. Have a safe trip and let us know how it goes. Very interesed in the results.
Old 04-23-2013, 08:13 PM   #8
SYE
SYE's Avatar
My pin weight is about 1950, I am at my maximum.
Scott & Vicki
Old 04-23-2013, 08:15 PM   #9
SYE
SYE's Avatar
I am nou quite sure it is sagging all that much, I also have Suspension Maxx on the front and makes the front end sit higher. I am thinking it is an optical illusion. I will measure it once I get it on level ground.I will lt you know as well
Scott & Vicki
Old 04-28-2013, 08:15 PM   #10
SYE
SYE's Avatar
Ok I just went on our first trip this weekend and it pulls real nice with RAS on my truck. Not as bouncy like it used to be. As for the sag it is not sagging like I thought it was I will post up a picture. Overall they are doing what I wanted them to do.
Scott & Vicki
Old 04-29-2013, 09:50 AM   #11
JoeMazz's Avatar
Awesome...glad they worked out. I too am at my pin weight limit and as much as I want an "install it and forget it" answer, I'm still on the fence between the RAS and the Airlifter 5000. I'll post a pic when I get it figured out.
Thanks again for your input.
Old 05-09-2013, 01:18 PM   #12
Cmon your trying to use a light duty truck to pull that trailer?? No wonder is sank with it hooked up. Yes I know the "dealer" said it was enough of a truck....but
guy driver is offline   Reply With Quote
Old 05-09-2013, 02:03 PM   #13
Wanna Be Camper
SaskCampers's Avatar
A 3/4 ton isn't exactly a light duty trck.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Old 05-09-2013, 08:39 PM   #14
SYE
SYE's Avatar
Mine is a 2500 HD it is a 3/4 ton with a 1 ton suspension!!
Scott & Vicki
Old 05-09-2013, 09:44 PM   #15
daydreaming about camping
jeeplj8's Avatar
I hope I am not raining on your parade, but when I first got My Excursion I had planned this upgrade. At the time everyone on The Excursion forum lived the RAS system. Then some people reported their system letting go under load. Apparently the shackle end would split on the spring. When they let go, it was under pressure and they did some damage. The more I read, the more afraid I was. I ended up canceling my order (which was actually back ordered at the time, again very popular. ) I ended up doing a spring upgrade instead.
I would make inspecting these past of your pre trip routine.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
