Old 02-23-2015, 02:44 PM   #1
Rubber seal disintegrating
We own a 2012 Sabre 32RSTC 5th wheel. Very happy for the most part. Were washing it with rubber roof wash and the seal above the kitchen slide disintegrated like marshmallow.
Anyone seen this before? Is it a flaw or bad rubber, or bad luck? Not sure where to turn at this point.
Dianizon
dianizon is offline   Reply With Quote
Old 02-23-2015, 02:48 PM   #2
TURBS's Avatar
Your camper site outside all year around?
I'd say the u.v got to it.
My 2011 sabre seals all look really good yet.
Ours is stored in my shop 6-7 mo. Out of the year.
Old 02-23-2015, 02:52 PM   #3
geotex1's Avatar
Seals can break-down very quickly depending on intensity and duration of UV exposure (don't mention where you camp and how long it's open in a season), especially if cleaned with improper chemicals and not treated with protectorant. Unfortunately, you'll need a replacement.
geotex1 is offline   Reply With Quote
Old 02-23-2015, 09:59 PM   #4
danielabram71's Avatar
What do you need to by to keep this from happening? I need to get it before mine does this
danielabram71 is offline   Reply With Quote
Old 02-23-2015, 10:21 PM   #5
geotex1's Avatar
303 Aerospace Protectant available at marine supply, CW at a ludicrous premium, Amazon, and good automotive detailing supply.
Old 02-23-2015, 10:44 PM   #6
X2. Great stuff!! It's important to get it on any new surfaces right after purchase to really get the full range of benefit from it.
rana is offline   Reply With Quote
Old 02-25-2015, 12:32 PM   #7
My trailer sits outside all the time. I made the costly mistake of not keeping my slide in when parked and not in use. The sun turned my top seal into mush as described in first post. If you are handy you can replace it yourself. I found out the hard way that if you go to a dealer and buy the seals a 10 foot double seal(inside and outside seal in one piece) will cost you $300 - $500. Once I pulled the seal I discovered the two seals are not connected and all I had to replace was the outside seal. Too late to return the one I purchased so I split in half and only replaced the outside seals. My seals had a bumper seal which was seperate from the wiper seal. I had to replace both. You can buy these seals on line at a fraction of the cost of going to a dealer. Just need to make sure what you need to order. I'm now keeping my slide in when storing.
Rod
2012 Sabre 250RLUD
2011 GMC 1500 Sierra
Max Tow, 6.2, 3.73
Rod, Debbe 1 spoiled Chihuahua and Becky the cat
1Texan is offline   Reply With Quote
