Old 08-06-2017, 09:23 PM   #1
NewBee
Send a message via Skype™ to TheRamaraos
Running Light Problem
I am sure this is not the place for my question. But here goes...
I have a 2015 Columbus 340RK. We have four of the 6 lights on the rear right side (brake/Turn signal) not burning. Any idea how I address this issue.
2 of the lights are working fine. Is this a short, fuse, or lights gone bad?
Would appreciate your help. We are on the road at this time, in Colorado.
The Ramaraos (Balaji and Indhu)
New to this lifestyle and have tons of questions
2015 Palomino Columbus 340RK
2015 Chevy 3500HD SRW Duramax with Alison
TheRamaraos is offline   Reply With Quote
Old 08-06-2017, 09:42 PM   #2
clr
TheRamaraos I would start by looking at the rear tail light assembly that is not working. Once you remove the cover you may be able to see what is causing your problem. The bulbs may have burned out or the socket that they plug into has rusted or something. If a visual check does not point to the problem you may have to break out the multimeter and start testing in round two.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is online now   Reply With Quote
