Old 11-07-2013, 12:25 PM   #1
Sabe 35qsik Dual A/C Question
Hello,
I just wanted to confirm that when you order dual A/C's from the factory the front unit is ducted just like the main A/C?
Also if the front A/C is added later it is NOT ducted?
Thanks,
Wlhm
wlhm is offline   Reply With Quote
Old 11-07-2013, 12:52 PM   #2
TURBS's Avatar
Originally Posted by wlhm View Post
Hello,
Thanks,
Wlhm
The 36qsik is a new model it'll be hard pressed to find many whom have one.
I'll see if I can find out for you.
Ps getting the second air installed at the factory is way cheaper..
Turbs
Old 11-07-2013, 01:00 PM   #3
TURBS's Avatar
Ok that was quick.
If two a/c's are installed at the factory there are both ducted.
If only one is installed then the ducting is closed off where second a/c will go.
In simple terms the second a/c is "ducted" ready if only one is installed.
If Your dealer installs the second air he can either duct it or not as that would be up to you which way you want it and what cost suits you.
Imo get it from the factory and be done.
Turbs
Old 11-07-2013, 01:17 PM   #4
jtstromsburg's Avatar
I added a second 15 I btu AC to our 34tbok myself, and it was easy to make it ducted. They simply foil tape off the duct work where you'd tie in the second AC. Actually, if not adding a second AC, I think I'd still open up the fan, or ceiling ducts, and seal it up so air isn't going further forward in the ductwork then needed.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is online now   Reply With Quote
Old 11-07-2013, 02:05 PM   #5
Camper Less Camping
Cajun Po-Boy's Avatar
X2...much cheaper to get second AC when you order your unit & it's not that much more of an expense relative to the total price your are already spending on the camper... a big plus for resell also.
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
