Old 04-28-2012, 05:51 AM   #1
ret2006's Avatar
Sabre 31 RETS-6-A/C condensate draining off back down on back window
New 2012 Sabre 31 RETS-6. This is the second time we have used the air conditioner and noticed the condensate runs directly to the back and down the back window. First time out I thought I may have not had the 5th. wheel completely level. I currently have it perfectly level and the condensate rolls right off the back and down the back window, quite a gush of water when the A/C cuts off. Looking at the roof ridge there is the traditional bead of Dicor but it isn't high enough to direct the condensate water to the side edges and into the small gutter.
This is my third fifth wheel and have never had this problem.
Anyone with this problem? Any suggestion on how to correct it? SabreSam, any suggestions?
2014 Cedar Creek 34 RLSA-7
2015 Chevy Silverado 3500HD LTZ SRW
ret2006 is offline   Reply With Quote
Old 04-28-2012, 12:22 PM   #2
How about something like this?
EZE RV Gutter System, 10' - Product - Camping World
Old 04-28-2012, 01:04 PM   #3
TURBS's Avatar
I wonder if you could put that across the back ?
Old 04-28-2012, 05:40 PM   #4
Here to Help
I will ask the plant for ideas on Monday.
SabreSam is offline   Reply With Quote
Old 05-16-2012, 06:27 PM   #5
racedaymechanic's Avatar
Originally Posted by Wiscampsin View Post
Thats what I did with mine, it worked like a charm
2009 Sabre Palomino "Sissy"
1998 Chevrolet K3500 6.5 Diesel "Brutus"
racedaymechanic is offline   Reply With Quote
Old 05-17-2012, 09:28 AM   #6
RET20065:
I had the exact same situation. My dealer re-torqued the AC hold down screws and the problem went away. I have my 31RETS-6 a year since and have not seen any evidence of condensate in that area. Steve
spat61 is offline   Reply With Quote
Old 05-17-2012, 01:27 PM   #7
Originally Posted by spat61 View Post
RET20065:
The water from the AC has to go somewhere, where im from water flows downhill, and the AC unit is mounted downhill, If there is no water coming off the condenser then the AC isnt working, or its leaking into your RV
