Old 07-03-2013, 10:34 AM   #1
Sabre 32 RCTS Hitch Question
Having a PullRite 2700 installed in my 2013 F-350 short bed on Monday. Was reviewing the owner’s manual yesterday and noticed there were certain measurements required. I called PulRrite and they are waiting for a photo I sent them to arrive. I noticed on the Sabres that the king pin is “Flat” versus being angled up and I also notice there are brackets welded behind the pin box. You folks pulling a Sabre 5th wheel with a PullRite SuperGlide, have you had any issues with clearances or such especially the king pin clearing the truck side rails?
Davidceder is offline   Reply With Quote
Old 07-03-2013, 10:46 AM   #2
Fulltime family RVer
The only issue that I have is the fancy cover/shroud thing hits my Retrax Pro bed cover on some turns. It's actually cracked the cover in one place. The king pin itself, has never made contact.
I will eventually either take it off when I put on a TrailAire/TriGlide or I'll trim 1" off of the cover itself.
ependydad is online now   Reply With Quote
Old 07-12-2013, 09:59 AM   #3
I trimed ~1/2 from the front of mine after I added a Mor/Ryde Pin Box becasue it would scrape the hitch plate when connections. Now, no more clearance problems.
Cathy & Jeff
Midland, Michigan
2013 Sabre 32RCTS / 2012 Ram2500 Hemi
SimchaSabre is offline   Reply With Quote
Old 07-12-2013, 10:18 AM   #4
I was actually swapping PMs with someone. I'm cracking up my pin box cover/shroud thing. I've got to cut a good 1" or so to stop busting it up on the RetraxPro cover.
As soon as I get my camper back from the dealer/factory, I'm doing it right away.
