Old 01-26-2014, 01:09 PM   #1
Pirates55's Avatar
Sabre 36QBOK-7 Question
Just wondering if there is enough room between the back tires to use a pair of these
Name:   ImageUploadedByForest River Forums1390759726.225640.jpg
My buddy has a sabre 34TBOK and his tires are so close together they will not fit. Just wondering about the 7,000 lbs axles.
Pirates55 is offline   Reply With Quote
Old 01-26-2014, 02:13 PM   #2
jtstromsburg's Avatar
Hmm. I have a '13 34TBOK & use the x chocks.
Sent by me
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 01-26-2014, 03:20 PM   #3
BombDoc's Avatar
Sent by me
Im thinking about purchasing these. Do you think it made a considerable difference? In your opinion, would you do the same thing again, or go with a different option? Thanks.
John & April & "Scout"
2013 Sabre 32RCTS-6
Nights Camped 2013-(44) 2014-(59) 2015-(47)
2016-(32) 2017-(13) 2018-(20) 2019-0
BombDoc is offline   Reply With Quote
Old 01-26-2014, 04:16 PM   #4
5erDriver's Avatar
Hi. They work great. Provide opposite lock on the wheels and for the money you can't go wrong. Really help with movement. From memory they go down to 1 3/8" at their smallest. Shop around. You may find a two pack on amazon for not much more than a single elsewhere. If you are looking for a little more stability I suggest looking at the universal stabilizers. Link below. They work good under the frame in a couple of spots. I use two along with a king pin tripod on my 5er. Still felt I had some movement even with the x chocks and tripod. My unit is 42 feet. Ultimately you are still on suspension so anything you can do will help with movement when parked.
http://m.campingworld.com/search/ind...p_sort_default
2013 Sandpiper 365SAQ
2008 Ford F350 Super Duty
6.4L Powerstroke Long Bed CC
5erDriver is offline   Reply With Quote
Old 01-26-2014, 05:23 PM   #5
Camper Less Camping
Cajun Po-Boy's Avatar
X chocks work great and are worth the cost...Unfortunately they didn't fit on our 32RCTS so I bought the custom fit RotoChoks that actually work even smoother than the xchoks...eitherway they help stop the back and forth movement a good bit...had front and rear bar locks and your in even better shape
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 01-26-2014, 06:30 PM   #6
Fulltime family RVer
RotoChocks for me.
Old 02-01-2014, 08:16 AM   #7
speedcat's Avatar
Yep...I use them. They fit and do eliminate a considerable amount of movement. Still have a bounce when the tribe runs and bounces off the walls.... and bunks.
2018 Heartland Landmark 365 Charleston
2008 Ford F350 King Ranch CC DRW 6.4l, 4.10 diff
B&W companion
Airlift system/on board compressor
speedcat is offline   Reply With Quote
Old 02-01-2014, 08:31 AM   #8
Pirates55's Avatar
Do you also have the JT Strong arms too
Old 02-01-2014, 10:17 AM   #9
I have JT's knockoffs called UltaFab Eliminators. I think if I had to do it again; I'd opt for the SteadyFast system. I like their marketing material the best.
To be honest, we still have quite a bit of movement. I could tell when my 8 year would roll over and there is definitely no hanky panky when my in-laws are along.
I want to install scissor jacks just ahead of the axles and get step supports for both steps next.
Old 02-01-2014, 10:31 AM   #10
speedcat's Avatar
I do have the JT strong arms and either they don't work like I expected or user error. I have followed the directions on leveling up 1/2 to 1" above level then lowering to put the appropriate amount of pressure on them. I then lower my rear stabiLizer. My X chocks went on first. I have come to the conclusion that a hydraulic leveling system is the best for ultimate stability. My RV buddy just purchased a Mac daddy Heartland Landmark. Our first trip with them is this spring. I can compare then. Although he says not much difference from the diesel pusher he traded. If that's the case Ill take it!
B&W companion
Old 02-01-2014, 10:40 AM   #11
Pirates55's Avatar
I ordered mine with the auto leveling system and the JT Strongarms
Old 02-01-2014, 11:05 AM   #12
speedcat's Avatar
Please let us know how that combo works. It was not an option when I ordered ours. When did you order and when do you expect delivery?
B&W companion
Old 02-01-2014, 11:12 AM   #13
Pirates55's Avatar
Ordered this week and expect it the end of march or the first of April.
Trying to get them to install a black tank flush in my 1/2 bath black tank too.
Old 02-01-2014, 11:24 AM   #14
speedcat's Avatar
Sounds about right for build time. I ordered ours last Jan and took delivery late Feb
B&W companion
Old 02-01-2014, 12:36 PM   #15
LaydBack's Avatar
I use the X-chocks and did find them as a pair priced comparable to what you usually see for one, so shop around online. My unit has the JTs, and yes, we know when the kids move in the bunkhouse. I just bought the BAL Fast Jack tripod that I'm going to add to the mix next season.
Sent from my SPH-L710 using Forest River Forums mobile app
LINK TO MY MODS
2012 F350 King Ranch DRW 6.7L
2013 Sabre 36QBOK-7 Platinum Package
LaydBack is offline   Reply With Quote
Old 02-01-2014, 01:26 PM   #16
Infractee
I do like the steadyfast system, seems to work well, price is good too.
RhoZeta is offline   Reply With Quote
sabre
