Old 11-05-2013, 04:04 PM   #51
TURBS's Avatar
Originally Posted by Sabre_Ray View Post
f1100, were you able to see or learn anything about the construction/installation of the rear walls. Ive seen folks talk about how they are assembled a little different than the sidewalls (no styrofoam or insulation). The reason I ask is because I think I may have an issue with mine, just not for sure.
Ray,
There was so much to see in a short amount of time but all walls had the same construction as well as the same insulation.
What kind of issue do you think u might have?
Turbs
Old 11-05-2013, 04:36 PM   #52
Sabre_Ray's Avatar
Well, first let me say that I have reached out to SabreSam who was very helpful in forwarding my concern to the warranty guy up at Sabre and we have exhanged some conversation also.
Background: I took delivery 12/13/2012 and my first documented concern for this is late january 2013 via email and phone call to the dealer.
If I walk up to the back wall (on the outside) and push on the wall, the whole exterior wall layer kinda flexes in and out (we're talkin' 1/8 - 1/4") as if the filon/luan layer is not really attached to the structure. The surface is not soft or bubbly, just more flexible than I assume it should be. The explanation that I've been given is that the rear wall construction is the filon laminated to the luan backer, all of which is glued to the wall frame, with the interior paneling attached to the inside (with no styrofoam or insulation like the other walls have). I know for a fact where at least one vertical structure member is under the window and from the outside there seems to be no adhesion of the exterior layer to the structure in that spot.
Ray, Christi and the kids
2013 Sabre Silhouette 291 BHTS
Sabre_Ray is offline   Reply With Quote
Old 01-19-2014, 08:20 AM   #53
Pirates55's Avatar
Can anyone explain the 3rd party PDI Inspection? If I end up buying the sabre it will have to be ordered and this may help with problems before delivery.
Pirates55 is offline   Reply With Quote
Old 01-20-2014, 06:24 AM   #54
TURBS's Avatar
We we're told to have our dealer request the third party pdi to the factory.
Now this may slow the delivery date of your trailer as well.
As they have factory trailers lined up for weeks, so keep this in mind.
TURBS
golf cart safety instructor
