Sabre Fifth Wheel: Damaged material needs a name
Hi All,
I have been trying to obtain some replacement material from Sabre for my 2015 33 CKTS-6. Today I received an email from the dealer claiming that the agent has no idea what this material is called or it's part number, so therefore no replacement.
I will do my best to describe this material and it location and if anyone know what it is called or where I can obtain a part number I will be in their debt for a looooooong time.
This material is located on the underside of the bedroom slide, butted up against the most forward piece of metal on the slide.
It has an adhesive on the back side and the front side is very gritty. It resembles a piece of safety thread that you could use on a stair to prevent slipping. The texture also is similar to the texture one would find on an asphalt shingle.
When the slide is retracted, the rollers supporting the slide sit on top of this material under the slide, so I would assume from that, it is somehow helpful in maintaining the horizontal position of the slide, but this is only my guess.
I will enclose some photos of what this materiel look like. I am taking the pictures from the ground up.
This material is roughly 5 inches deep and 60 inches long.
Any help on this would be greatly appreciated.
David
