Old 07-10-2016, 02:53 PM   #1
The pope's Avatar
Sabre slide Outs both have sliders coming off!
On both of the 2 large slidouts the material that they slide on is coming off. Will retract one more time and off to the repair shop.
Has any had this problem. Appears to be a factory defect. it appears that both slideouts need to be removed from trailer to install new material that they slide on.
Name:	ImageUploadedByForest River Forums1468180301.596911.jpg
Name:	ImageUploadedByForest River Forums1468180320.850505.jpg
The pope is offline   Reply With Quote
Old 07-10-2016, 03:59 PM   #2
Fulltime family RVer
This happened a bunch a while back. Hopefully someone that had it happens chimes in. But yes, this isn't uncommon on Sabres.
Old 07-10-2016, 04:41 PM   #3
jtstromsburg's Avatar
Yes my previous Sabre 34tbok did it on two slides. I got it back in place and added screws till I could get it in for warranty and fixed right. Basically the factory holes in the poly piece were too large and the screw heads pulled thru.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 07-11-2016, 01:18 PM   #4
Hey Pope;
What Model and Year is your unit?
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 07-12-2016, 04:17 PM   #5
We have a 2009 year model 28RETS w/3 slides that have lot of use, believe me. No this has never happened, thank goodness.
cruisin
cruisinhwy66 is offline   Reply With Quote
Old 07-12-2016, 08:07 PM   #6
Jimsue's Avatar
We had same problem with our 2013 Sabre. Took it back to factory and they repaired it free with no hassle. Talk to Carey Jones at (574) 642-3079. He and his crew were very accommodating .
2015 F350 Lariat Crewcab DPS SWD 4x4
2013 Sabre BKOK 31
andersen ultimate 5th wheel hitch
Renogy Solar Suitcase
Progressive Industries EMS
Sea Eagle 420 Tandem Inflatable Kayak
Jimsue is offline   Reply With Quote
Old 07-12-2016, 08:10 PM   #7
BuckeyeChuck's Avatar
Same thing happening to my '13 33ckts kitchen side slide.
2012 F250 Super Duty
2013 Sabre 33CKTS
BuckeyeChuck is offline   Reply With Quote
Old 07-12-2016, 09:07 PM   #8
satdog01's Avatar
Had these fall off my 2012 Flagstaff 831fkbs. The slide actually scored or dug into the vinyl flooring. Takesd to FR and they advised to replace the item before more damage occurred. Pieces are held in by a couple of screws and are easy to replace, when the slide is extended. Ours fell out, so I added a couple of strips of to the floor where the slide came in. Solved the scoring issue and slide seemed to retract easier.
Marriot II on Wheels 2017 Flagstaff Classic 832OKBS Diamond Pkg
2013 GMC Denali crew 6.6L 2500 HD DMAX w\Alison Trans
Pepper 🌶 Pomeranian rescue 289 nights as camping buddy
Days camped in FR, 2011-12 = 77, ‘13 = 59, ‘14 = 39
‘15 = 52, ‘16 = 77, ‘17 = 81, ‘18 = 44, 2019 = 45
Retired :
satdog01 is offline   Reply With Quote
Old 07-17-2016, 07:50 AM   #9
The pope's Avatar
The trailer is a 2013 33rets.
Old 07-17-2016, 08:10 AM   #10
The pope's Avatar
I will not go back to the dealer that I bought it from. To small of an operation to repair much. Its at a big shop now and parts are ordered. The slides need to be taken out. I had to get an extended warranty from Good Sam since the trailer is so poorly designed and constructed. It is covered. I'm amazed and all the issues that I've had with this trailer. The hubs are being serviced for the 1st time and there were 2 issues with the brakes that were assembled wrong from the factory, one was wired wrong and was not operating at all and the other was a part was "missing". When I pick it up I'll get the full story. Just waiting for the next design, assembly problem to appear.
sabre, slide, slide out
