Old 10-29-2012, 08:09 AM   #1
ret2006's Avatar
Sabre winterization question
I just finished winterizing my Sabre for the first time. Although this is my third fifth wheel, I went by my dealer recommendations which were pretty basic and the way I have always done it. With the exception of TWO things. A disclaimer at the bottom of their instruction sheet said "The use of air pressure to blow out the water lines will void your warranty". Never seen or heard of this before.
The other item and question I have is "after draining the hot water heater (Surburban 12 gallon) with anode rod, leave the anode rod out". I noticed when I picked my Sabre up last January it was winterized and the anode rod out. BUT, the threads on the water heater were very, very rusted. I had to use a wire brush to clean them prior to installing the anode rod and filling. I always put the plug back in my Atwood heaters and rods back in Surburban's after draining. Any advice or suggestions on this?
2014 Cedar Creek 34 RLSA-7
2015 Chevy Silverado 3500HD LTZ SRW
ret2006 is offline   Reply With Quote
Old 10-29-2012, 08:33 AM   #2
1st time winterizing our Sabre too and I blew put the lines before pumping antifreeze thru. If you keep the air pressure low, say 30 PSI, I don't see where there would be a problem. I replaced my anode rod too.
Old 10-29-2012, 08:53 AM   #3
Road-King's Avatar
Th only thing I can think of is someone out there used too much pressure to blow out their lines, so the dealer is CYA's. I would use low pressure and I would not tell them I blew them out.
I always put the rod back into the tank. Like you said the threads get rusted if you don't. Also with that open, some insect may decide your tank will make for a nice home. With the tank drained, I don't see the need to leave it out...
Russ & Kim
2014 Alpine 3600RS
2007 Dodge Ram 3500 5.9 4X4
2008 Harley Davidson Road King 105th Anniversary
(2011-5 bad year)(2012-40)(2013-45)(2014-23)
Road-King is offline   Reply With Quote
Old 10-29-2012, 09:08 AM   #4
Camper Less Camping
Cajun Po-Boy's Avatar
X3 on putting rod back in tank after emptying
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 10-29-2012, 09:16 AM   #5
X4 On replacing rod...Also...I never blow out prior to adding antifreeze. I rather displace water than air as we go through the camper opening the varuious plumbing outlets. personal preference I guess!
Cathy & Jeff
Midland, Michigan
2020 Cedar Creek 34IK / 2019 Ram3500 CID
SimchaSabre is offline   Reply With Quote
Old 10-29-2012, 05:06 PM   #6
H2oski
X5 Reinstalling/Replacing rod and reguleaed belo 3 PSI. IMHO.
Wife
2007 Chevy 2500 HD 6.6
2012 Sabre 31RETS
(LA) Lower Alabama
h20ski is offline   Reply With Quote
Old 10-29-2012, 05:38 PM   #7
phat phrog stunt crew
have never blown lines out, just add anti freeze until pink flows from all faucets. then a few splashes down the p traps and that pretty much does it. am curios now tho about the water filter on my sabre. how do you folks handle that?
dwaynerz is offline   Reply With Quote
Old 10-29-2012, 06:06 PM   #8
ret2006's Avatar
I made a by-pass for my filter. Turn by-pass valves take the filter housing off and throw the filter away. I put the housing back on but it will be empty.
Old 10-30-2012, 10:28 AM   #9
This is the first year I've had a water filter to worry about and I though about adding a by-pass set-up like ret2006 did...
but...
I went cheap instead and just used a 6" pvc 1/2" nipple to connect the filter's inlet and outlet hoses. I figured it wouldn't be much harder to install the nipple that than it would be to reach in and turn 2 by-pass valves. But I did NOT figure on getting cold water down my sleeve as I was installing it...so I may rethink that for next year.
Cathy & Jeff
Midland, Michigan
Old 10-30-2012, 10:54 AM   #10
Road-King's Avatar
I did something similar, I didn't use valves, I removed the filter housing and connected the two male pex ends with a 6" hose with two 1/2" female ends.
I will not re-install the filter housing in the spring. I use an external filter in the water line/hose connected to the city water hookup.
Russ & Kim
2014 Alpine 3600RS
