Old 09-08-2016, 10:43 PM   #1
Unhappy Satellite and cable in Columbus 385bh 2016
Anyone know why I can't get carry out satellite dish to connect to tv's in my camper? Cable is not working either. Three tv's---Direct tv receivers.
Debnc6 is offline   Reply With Quote
Old 09-08-2016, 10:48 PM   #2
Berkshire 390QS
NO3putt's Avatar
What kind of recievers and what kind of portable dish? Would suggest first you try to run direct single cable from satellite to one reciever to make sure your dish is working properly.
2015: 188 days, 2016: 72 days, 2017: 185 days: 2018 182 days
Old 09-09-2016, 06:44 AM   #3
If cable is not working either, then I would start there. The cable connector on the outside of the RV goes to a switch that selects antenna vs cable. You need to find it. On some it is built into the antenna booster switch. You need to find that since you will need to disconnect the feed from the outside connector and run it to your satellite receiver. Then put the output of your satellite receiver to the same connection...
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 09-09-2016, 07:06 AM   #4
TURBS's Avatar
On my Columbus the satellite and cable "in" connections were switched.
I had to connect my satellite coax to the cable in port.
When in goshen they fixed that and then the tech asked if I've tried to use park cable, I hadn't, he said well it wouldn't have worked anyway so he fixed that right away to.
They never could get a good signal to the bedroom tv so they ran new cable.
Old 09-09-2016, 07:26 AM   #5
Oops, just re-read your post. 3 TVs? Each with DirectV receivers. Unless they are SWM, that is a complicated install and a single cable won't work anyway. If you want more than 1 receiver, you need a dual LNB dish with 2 separate cables, one to each receiver. If you want more than that you will need 2 cables and a MUX adapter for DirectV.
2015 335DS
Old 09-09-2016, 07:37 AM   #6
BandJCarm's Avatar
Unless you're using the GENIE system.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 09-09-2016, 08:16 AM   #7
Seems to be the case, but then you need an SWM dish and cabling, but you do get HDTV!
2015 335DS
Old 09-09-2016, 06:28 PM   #8
89tta500's Avatar
Send a message via AIM to 89tta500 Send a message via MSN to 89tta500
Wireless GENIE is the best! I can put my small boxes anywhere in reach of power and the GENIE WI-FI signal!
2016 XLR Thunderbolt 420 AMP
2006 GMC Topkick C5500 8.1l on Propane
89tta500 is offline   Reply With Quote
Old 09-09-2016, 10:05 PM   #9
cable
If you are trying to use the outside cable connector through the booster/splitter it will not work with sat. signal whether the booster is on or off.
It would help to know what sat. dish and receivers you are using.
I use sd receivers with the 18" round direct tv dish and it will feed two sd receivers without a multiswitch. But I had to run a seperate cable from receivers to the outside wall with a furrion covered connector.
markb422 is offline   Reply With Quote
cable, columbus, satellite
