Old 10-13-2017, 07:36 PM   #1
Satellite connection
Can anyone tell me where the satellite connection is on a 2017 Columbus 383FB is.
Bznite 4 is offline   Reply With Quote
Old 10-14-2017, 10:31 AM   #2
I have a new 320 and the connections are in the storage area on each side... they are labeled; doesn't necessarily mean they will work or labeled correctly (cable/satellite) keep at it... finally just brought it in through the side window. Less frustrating.
Beermaker is offline   Reply With Quote
Old 10-14-2017, 09:37 PM   #3
Thanks the connection in the storage area does not work.
Old 10-17-2017, 08:52 AM   #4
The connections are in the water closet where you connect your water hose, etc. The two connections in the basement are fed from the water closet connections. I think the AUX connection in the water closet is for getting the signal to the basement for a tv. I can tell you the connections in ours were all wired wrong so I had to switch some cables. Good luck!!
condojj48 is offline   Reply With Quote
Old 10-19-2017, 10:17 AM   #5
Thanks for the info. The connection that is supposed to be in the water closet,is not.
Old 10-22-2017, 09:20 PM   #6
I got mine to work... in the 320 in underneath storage there should be at cable/satellite connection... behind your tv on the wall there should be the same connection.
Look close... there should be a cable all ready running to tv and a button with a light, press the button to turn off Antenna... that will allow satellite to operate
Old 10-31-2017, 01:43 PM   #7
Did find the connection in the water closet,up by the faucet. It blended in to the wall. When i saw it with the sun just right. It was there big as life. Must be blind. Thanks to the people that responded.
Old 11-04-2017, 09:34 PM   #8
You are welcome!!
Old 11-04-2017, 09:52 PM   #9
Did have to rewire.
lite, satellite
