Old 04-15-2013, 09:29 AM   #11
The booster switch won't have any effect on this. It sounds like maybe they put a staple thru the coax or managed to cut it. Warranty?
Old 12-26-2013, 04:37 PM   #12
Columbus 365. Behind my living room TV is 3 connections: 1. Antenna/Cable 2. Satellite/Aux (runs to hookup in basement by water) 3. Satellite and have no idea where the other end goes. I am looking at a roof mounted dish and would like to know where the cable is.
rmason8092 is offline   Reply With Quote
Old 12-27-2013, 08:05 PM   #13
I have the Columbus 365RL and it is wired like this.
No cable connected to SAT connector in the basement.
Old 12-31-2013, 08:51 AM   #14
columbus ties the two tvs together with splitter
The splitter doesn;t work with the satellite. We have the same configuration. You have to go underneath and get rid of the splitter. Wires must go directly to each tv and not be split. Go under the stairs.
Justired is offline   Reply With Quote
Old 12-31-2013, 08:55 AM   #15
Phat Phrogs Incognito...
DutchF's Avatar
The splitter show in the diagram, does work. With DirecTV satellite systems. In fact, it is the only way to get the signal to multiple receivers / TVs. The thing is, unlike many TV type splitters, the one shown is the correct frequency AND DC pass through.
Tina + Dutch and Bell, Bobo, Harley, Buddy (the dogs)
2011 F350 Lariat 4x4 DRW SuperCrew 6.7L (B&W setup w/Air Lift 5000 Ultimate)
2014 Columbus 365RL (Airflex and Voyager package)
Nights Camped 2014 - 154, 2015 - 32, 2016 - 4
DutchF is offline   Reply With Quote
Old 12-31-2013, 11:14 AM   #16
I am using it in my house and in my camper. It does not work with the older dishes.
Old 01-01-2014, 08:55 AM   #17
Satellite Connection
The splitter does work with the SWM3 dishes. Does not work with most dome dishes. I have a Winegard carryout automatic for when the trees block the roof mount. Then I can't use the splitter. Then we can only watch on one TV or run an extra cable from the Satellite to a second TV usually outside.
