Old 04-15-2012, 10:45 AM   #1
Satellite hook up
NO INSTRUCTIONS FROM SABRE OR TOSBIA TV ON SATELITE HOOK UP. I JUST PURCHASE A34REQS 6 AND I THINK FOREST RIVER NEEDS TO TAKE A LOOK AT THEIR MANUALS AND WHAT THEY PROVIDE TO THE OWNER AS FAR AS WHERE THINGS ARE AND PROPER MAINTANCE. VERY POOR INFO.
IF ANYONE CAN GIVE ME INFO ON SATELITE IT WOULD HELP. MY JAYCO HAD A CONNECTION ON THE BACK OF TV FOR AIR ANTENNA AND ONE FOR CABLE AND SATELITE THIS ONLY HAS ONE HOOK UP ON TV FOR COAX.
THANKS
DUCHIE
duchie is offline   Reply With Quote
Old 04-15-2012, 10:49 AM   #2
TURBS's Avatar
whoa dutchie !!
you are giving us about as much info as an rv manual . very little to go on .
are you looking for a sat "in" connection on camper ? if so is it not in the water control center ?
Old 04-15-2012, 10:52 AM   #3
TURBS's Avatar
like this ? Click image for larger version
And to be quite honest if you would have had a COMPLETE PROPER pdi inspection the dealer should have should you this .
1 sat hookup
2 how to run and operate your all you rv appliances
true the manual leaves much to be desired but they give you ALL your appliance manuals to search there site for info .
Old 04-15-2012, 03:15 PM   #4
bikendan's Avatar
duchie, just for info, using caps to type, is considered YELLING on forums.
Equalizer WDH
Old 04-15-2012, 03:33 PM   #5
Originally Posted by f1100turbo View Post
like this ? Attachment 12195
1 sat hookup
It is inside in the tv compartment,and on the back of the tv. you only have one conection on the back of the tv for ant. cable satelite where as my rca tv in my jayco had one for ant and one for sat/cable. maybe that is the way it suppose to be but it doesnt seem right/????
Old 04-15-2012, 03:39 PM   #6
cardinal4fun's Avatar
The coax coming from the back of the TV will go into the sat receiver. You will more than likely have to have the TV on channel 3 to get the sat signal.
3500 Ram 5.9l diesel
08 35 RLT Cardinal
5th Airborne Pin Box
cardinal4fun is offline   Reply With Quote
Old 04-15-2012, 03:54 PM   #7
TURBS's Avatar
I use the rca cable for mine.
I also used the coax one on outside tv
