Old 03-04-2014, 02:46 PM   #1
Satellite Splitter Location
We have a Columbus 2014 Model 325RL. We were camping in Key West which has no TV so bought a Dish Tailgater. The automatic antenna gets 12v DC via the Coax. Unfortunately the sat cable splitter in the Columbus does not pass DC voltage. I ended up having to run the coax in a window. I can get a splitter that passes 12v DC but I can't figure out where the factory put the splitter. Anyone know where it would be?
Rreilly is offline   Reply With Quote
Old 03-04-2014, 05:04 PM   #2
hd riders's Avatar
We just got a Winegard Pathway2 have not hooked up yet but would also like to know how to get power to it??? We have a Columbus 320RS
hd riders is offline   Reply With Quote
Old 12-30-2014, 05:12 PM   #3
As far as I know there is no splitter. The outside sat in connection is NOT connection to the Sat connection located behind the TV. The outside to inside connection is on the same panel as the rooftop/cable connector. The other Sat connection is connected to the bedroom TV. Lousy labeling to say the least.
seahawk986 is offline   Reply With Quote
Old 01-07-2015, 01:29 PM   #4
I have a 2013 320RS. The location is behind the water connections in the belly of the beast. Unscrew the wall behind the water connections .
rvjoea is offline   Reply With Quote
Old 01-14-2015, 08:18 PM   #5
Make sure the connections are not reversed. Some folks have found the cable and satellite connectors are mislabeled.
Tom
nineback is offline   Reply With Quote
Old 01-14-2015, 08:28 PM   #6
Mr. Dan's Avatar
This thread had no inputs from early March to late December. Strange. I wonder if the OP solved his problem.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 86; booked = 0
cat, location, satellite
