Old 09-30-2016, 12:10 AM   #1
Sawdust in LED overhead lights
Just acquired a used 2015 Palomino Puma 25RS. Doing the usual upgrades all RVer's tend to do to make their unit theirs.
All of my overhead LED light fixtures have a fair amount of sawdust lying in the lenses. I've seen this on every RV I've owned the last 40 or so years, but have had no problem removing the lenses to clean out the dust. However, so far, the lights are resisting my meager efforts to remove the lenses. As I've not encountered these type of lights before, before I break something I wanted to ask if anyone knows how to remove the lens so I can clean them.
Thank you for any help I can get!
MissouriBob is offline   Reply With Quote
Old 09-30-2016, 05:43 AM   #2
davel1971's Avatar
a picture would help, as there are many light styles in the RV industry
David & Lynn
Old 09-30-2016, 07:55 AM   #3
Head Rambler
As Dave (or Lynn) said, a picture would help as there are several different styles of fixtures used in RV's now days.
If they're the divided fixtures, the lens pry away from the divider a little and then pull down. If they're the solid oval units, the lens squeeze together a little and pull down.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 09-30-2016, 08:16 AM   #4
dieselguy's Avatar
If you are talking about the 3-4" round frosted domes on your LED lights ... although a bit stubborn ... they just pop off. Some have a small slot so you can place a small screwdriver in and twist.
dieselguy is offline   Reply With Quote
Old 09-30-2016, 12:39 PM   #5
Nurek's Avatar
I've got styrofoam bits in my lights and they are not so simple to open as one would think. If I insert a flathead screwdriver or panel popper into those little slots, there is no movement and the light looks like it is prying off the ceiling.
Nothing good can come from forcing plastic.
2011 Nissan Xterra V6
2016 Rockwood MiniLite 2306
Nights Camped 2016 [24]
Nights Camped 2017 [63]
Nights Camped 2018 [27]
Nurek is offline   Reply With Quote
Old 09-30-2016, 01:02 PM   #6
The white bezel/trim does not pop off.
The frosted center lens pops off the white trim.
Slide something thin (like a utility knife blade) in between the two, twist slightly and pull downwards.
Once apart, you'll see how it all works. Those slots near the ceiling are deceiving.
Days Camped: '16=46 '17=30 '18=51 '19=36
Old 09-30-2016, 01:08 PM   #7
Nurek's Avatar
Thank you my hero of the day!
Old 09-30-2016, 01:20 PM   #8
Senior Gold Member
rthomaslyons's Avatar
If they are the oval shaped lens, I take my Stanley carpenter clamp and gently squeeze the ends a bit and then I can pop them out by squeezing the sides with my fingers.
rthomaslyons
2019 Sunseeker 3010 DSF
rthomaslyons is offline   Reply With Quote
Old 09-30-2016, 07:12 PM   #9
dieselguy's Avatar
If your lights are like these ... like said stick a small screw driver in slot on lens and twist. The base is screwed to the ceiling.
Old 09-30-2016, 09:04 PM   #10
led lights
If they are 4 or 5 inch dia. round translucent cloud type, they unscrew.
markb422 is offline   Reply With Quote
led, light
