Old 07-14-2016, 01:16 PM   #1
Sealant Question
I want to inspect and if necessary touch up the sealant on the roof of my 5'r.
Having never done this I was wondering about self leveling sealant. Will this stuff so loose it will run off a curved section of the roof? I imagine I will need to seal around skylights, fans, vents, etc and maybe the front cap.
Any suggestions are appreciated. Technique, product. Can I caulk directly over the old caulking?
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 07-14-2016, 02:12 PM   #2
Self leveling lap sealant is pretty viscous, about like peanut butter, but if applied to a vertical or sloped surface it will slowly flow down until it sets. It will flow faster in the sun. Having said that, it's not what would be considered runny at all. And when you apply it, it looks like regular caulking, but it slowly spreads out for a few hours.
Gotta go campin!
Old 07-14-2016, 02:23 PM   #3
I go RV'ing not Camping
jgourlie's Avatar
x2
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
Old 07-15-2016, 11:12 PM   #4
guitardoc64's Avatar
The simple rule is that if you think you put too much, it's probably good to go.
2013 Ford F150 Ecoboost known as Lightning
Palomino Puma 31DBSS
guitardoc64 is offline   Reply With Quote
Old 07-16-2016, 01:43 PM   #5
If you are going to invest the time to reseal your roof, please consider using Eternabond tape. The extra effort is worth the return on your investment as it is more durable and looks better than lap sealant.
Eternabond is something I recommend every camper get even new ones right out of the factory.
Skyliner is offline   Reply With Quote
Old 07-22-2016, 09:07 AM   #6
BuckeyeChuck's Avatar
Make sure if you are suing sealant you use one that is compatible with your plastic skylight. Some will attack the plastic.
2012 F250 Super Duty
2013 Sabre 33CKTS
BuckeyeChuck is offline   Reply With Quote
Old 07-22-2016, 09:07 AM   #7
Second the eternabond option.
2013 Sabre 33CKTS
