Old 07-14-2012, 08:12 PM   #1
Great Horned Owl's Avatar
Setting up new Puma
I picked up my new Puma 253-FBS and I've been busy getting it set up. With lots of little problems popping up, its taking longer than I had anticipated.
I put in two big golf cart batteries, only to discover that they are too big for any of the readily available battery boxes. I finally found some and then discovered that the existing battery vent uses 1-3/4 tubing which is an oddball size. Fittings are not available.
Installing two roof vent covers went fairly smoothly, except that while we haven't had a drop of rain for three weeks, it started pouring while I was up on the roof. Scrambling down, I lost a screw. Oh well, another trip to the hardware store.
I can't believe that they would make a rig like this without a single 12 volt receptacle. I was also surprised to discover that I can't find a panel mount 12 volt outlet at the hardware store or auto parts store. I'll be taking another trip to Camper World.
One feature that seems to be a real problem is that with the slide in, the dinette table completely blocks access to the range, fridge, bathroom, and bedroom. I am thinking about taking the table top off of the legs and replacing it with a length of 1 x 14 (if I can find any). Then I can fasten the table top to the 1 x 14 with a piano hinge. The table would then flip up out of the way. Has anybody tried anything like this?
Joel
2011 Silverado 2500HD Duramax, 4x4, crew cab, long bed
Palomino Puma 253-FBS, 27' 5th wheel
1994 19' Class B on Chevy chassis
Great Horned Owl is offline   Reply With Quote
Old 07-17-2012, 11:03 PM   #2
TURBS's Avatar
you can order 1 3/4 a/c duct tubing from auto store . I got mine from oreillys
also got a double 12 v outlet water proof from oreilleys .
Hope this helps .
Ron
