Old 10-30-2013, 08:00 PM   #11
Timex's Avatar
I have the little drainage as well but nothing to cry over. The only issue I have in regards to this is the end cap gets a suction on the pipe almost to the point that sometimes I think I would get it to turn and come off. I may try a little plumbers grease around the seal to lubricate things.
Timex is offline   Reply With Quote
Old 10-30-2013, 08:03 PM   #12
wilem's Avatar
Sound like your tank vent is stuck closed, mine has one under the kitchen sink and bathroom sink.
William
Master ASE
Private pilot SEL
A&P
jack of all trades master of one...LOL
http://imageshack.us/a/img32/3111/ypy.JPG
wilem is offline   Reply With Quote
Old 10-30-2013, 08:52 PM   #13
tomjsas's Avatar
My bathroom gray tank does the same thing. The Kitchen one doesn't. But, the Bathroom and Black tank handles go into the underbelly and contol valves remotely. The kitchen gate is separate and is right at the connection. So, I attribute it like others have, may be some residual in the pipe that gets jostled to the cap by the next time I'm ready to take it off. At least it isn't sewage. Always smells like soap or shampoo from the shower thank goodness!
Tom
Pull-Rite 16K Super 5th
2014 Rockwood Signature Ultra-Lite 8289WS
2011 Chevy 2500HD - DuraMax (Just over 5000 miles now!)
Nights camped in 2014 - 21
tomjsas is offline   Reply With Quote
Old 10-30-2013, 09:01 PM   #14
Rugged Brown's Avatar
If there is significant distance between valve and outlet, it may be possible that the drain pipe is not completely drained before you replace the outlet cap. Leave the cap off and let it drain.
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 10-30-2013, 09:11 PM   #15
Platokidd's Avatar
Several units over the years and never had that happen.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 10-30-2013, 11:26 PM   #16
Great input
Thanks everybody. great input. I think I will try to figure out which grey tank it is by only dumping one of them and going onto my next spot, and seeing if I have any residual. I can always dump tank 2 when I arrive at camp. Not going to worry too much about this base on all your input.
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 10-31-2013, 11:12 AM   #17
I had this happen with my old camper but only after several years of use. I suspect the valve seals were breaking down. Interestingly, I found a sizable wood shaving come out of my tank last week on my new camper (just took delivery a couple of weeks ago.)
campingguy is offline   Reply With Quote
Old 10-31-2013, 03:19 PM   #18
Timex's Avatar
Tank vent?
You wouldn't have a picture of this tank vent would you? And is it easily accessible and how do you unstick it?
Old 10-31-2013, 03:40 PM   #19
Put an end of line dump valve on and you won't have any drainage until you hook up your sewer lines. I winterized the 5er a couple of weeks ago, in my driveway. Poured about 4 gallons of water into the black tank via the toilet. When I opened the black tank valve, there wasn't much that came out until I raised the front end up past being level.
Pipeman is offline   Reply With Quote
Old 10-31-2013, 10:30 PM   #20
wilem's Avatar
it is on a stand pipe under each sink in my camper. 2 " in diameter the top is vented with a soft silicone diaphragm in it Similar to that of a respirator. It is threaded on.
Amazon.com: Lasalle Bristol 74PV240BB Vent Valve: Automotive
William
Master ASE
Private pilot SEL
A&P
