Old 04-09-2018, 09:20 PM   #1
shackle failure on a columbus 320
I have a columbus 320 5th wheel and had a pair of shackles break at the bolt hole area, the tires were rubbing together for a short time, the trailer is 5 years old, luckly I noticed the tires while fueling up, has anyone had similar failures,
bigfiver is offline   Reply With Quote
Old 04-12-2018, 10:28 AM   #2
I lost one
I had one break as well but did not have the tire rubbing issue. I replaced mine with a Morryde heavy duty shackle kit (twice as thick) They are also greasable with the zerk fittings and come with brass bushings. I had plastic bushings. I decided not to use the brass bushings and got some Lippert neverfail bushings. I tried to get the Lippert heavy duty kit but they were never able to fill my order. I feel a lot more comfortable with the heavy duty kit. I also replaced my equalizer suspension since the rig was already torn down and the suspension was 5 years old.
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 04-14-2018, 09:48 AM   #3
I also had the shackles wear out but noticed the wear before they broke. Upgraded to the Morryde SRE 4000 system.
Dave Mun is offline   Reply With Quote
Old 04-17-2018, 09:21 PM   #4
Last October on a trip back from New England States the shackle tore loose on drivers side on rear axle and tires we're almost touching when I discovered it. Wabash trailer center got us back on road , cost us $350.00 , the service tech said the shackle was 5/16" thick. Forest River is making these 5th wheels for weekend people .
VetL82 is offline   Reply With Quote
Old 04-17-2018, 09:24 PM   #5
TURBS's Avatar
With the weight of these rigs shackles and bushings need to be checked as a pre/post trip inspection.
Lippert uses cheap nylon bushing that doesnít last very long, upgrade to wet kits.
Old 04-17-2018, 09:41 PM   #6
Upgrade
Upgrade to a heavy duty shackle before they break......because the WILL.
Old 04-17-2018, 10:00 PM   #7
amxpress's Avatar
Wow. I just picked up my 2013 320RS from the shop this morning. I replaced the springs, shackles, bolts, & Equa Flex. The holes in the shackles and spring bushings were rounded out, what we call ďwollered outĒ down here in the South. I think installing bronze bushings with wet bolts, as well as thicker shackles should be performed after a couple years. That being said, my brakes werenít even worn 50%. This after trips though mountains from NC to Colorado.
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
amxpress is offline   Reply With Quote
Old 04-18-2018, 12:22 AM   #8
SYE
SYE's Avatar
Had on break on my 295, replaced with MorRyde Cre 3000 and shackles with wet bolts
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 43 Nights Camped 2018 27 nights reserved
SYE is offline   Reply With Quote
Old 06-01-2018, 08:29 PM   #9
Columbus shackle failure
I just installed new grease type shackles and bolts with brass bushings, the new shackles are 5/16 inches thick , so this repair should finalize this under designed suspension issue, thank to all that have replied, Happy RV ing
columbus
