Old 09-01-2014, 10:33 PM   #1
asquared's Avatar
Should this go back to the factory?
It is no secret we've been having some issues with our new Sabre 34REQS since we bought it in mid July. In the beginning it was mostly little annoying things like trimwork issues. Then after we took possession bigger issues have been popping up. The microwave didn't work right and was replaced. The bedroom slide actuator assembly sheared away from the floor pinching wires. They had to rerun all the wires and redo the slide actuator assembly. The shower fiberglass has some cracks in it.
1 week ago we noticed the slide seals on our other 3 slides were tearing and pulling away from the sidewalls of the trailer. Ok so we need some new seals. Contacted the dealership who has been great to work with so far. Sent them some pics and the first question out of the service managers mouth was, why is this happening. As of when we discussed things last week, his plan was for me to bring him the 5er when I could leave it for quite some time as he planned on taking the slides apart and figuring out the cause.
Well this weekend we had a mobile rv repair guy at the site and he immediately noticed the cause. The holes for the slides are not cut correctly. The holes are wider at the top than the bottom. The bottom is too tight causing the slide and slide seals to bind. This has also caused the propane line to the fridge to bind in the slide. We ended up with holes in the propane line. We discovered the propane line Fri night as we were getting ready to pull out. There was a mobile repair guy in the campground giving a seminar so we had him take a look at the propane line. That's when he discovered the slide issue. He also said when the slide was in and binding the propane line it was pushing the sidewall in causing a dent. 3 of my 4 slides have this hole cut incorrectly. The bedroom slide appears to be ok. This is a pretty major issue. My question is, when I contact the dealership this week, should I let the dealership attempt this fix or insist the 5er be sent back to the factory for a fix? Is this fixable? Not to sure what to be insisting on at this point. I know I have been fortunate in that my dealership has been very accommodating and quick with repairs to this point but I'm worried this might be a bit too major for them. Any thoughts here? despite all of our issues, we still love this trailer. As long as things can be made right, we will be ok. But how to make them right?
These pics don't do the issue justice but here are some nonetheless.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 09-02-2014, 08:03 AM   #2
Thankfully you've got a good dealer to work with. Most dealers can/will replace slide seals. But if the slide holes are not cut correctly that is a major issue and I would hope they send it back to the factory for the fix.
Old 09-02-2014, 01:28 PM   #3
Talk to your dealer since you have a good relationship. I imagine he wont take on fixing the walls.
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 09-02-2014, 01:37 PM   #4
ARLO
My vote is factory. They have the rigging and jigs for large repairs. Flagstaff did a great job replacing my floor.
rlocicero is offline   Reply With Quote
Old 09-02-2014, 01:49 PM   #5
Brother Les's Avatar
Seals...easy to change out.
Slide size issue... your Dealer will let you know which direction he/you will take.
Brother Les
Old 09-02-2014, 06:41 PM   #6
asquared's Avatar
Thanks guys. I played phone tag with the dealership today... I called them, they were out, they called me, I was in with a patient and so on. Hopefully we will connect tomorrow. They have really been great to date, I'm just nervous letting.g a dealership handle something this big.
2014 Sabre 34REQS-6
Old 09-07-2014, 02:36 PM   #7
asquared's Avatar
Here are some more pictures. There is over an inch difference in the distance between trailer and slide from top to bottom.
ID:	62298   Click image for larger version
ID:	62299   Click image for larger version
ID:	62300   Click image for larger version
ID:	62301   Click image for larger version
2014 Sabre 34REQS-6
Old 09-08-2014, 12:15 AM   #8
Factory, if possible
NeilM108 is offline   Reply With Quote
Old 09-09-2014, 02:28 PM   #9
Just found out our new 2015 Coachmen Chapparal Signature fifth wheel is going back to factory next week. We have used it twice since getting it June 21. It was back at the dealership for 2 weeks. They attempted to fix the problem. Slide seals. If you drive on wet roads, the tires kick the water up and under the slides leaving very wet floors and carpet. We love our camper and I really hate to see it go but it has to be fixed.
LindyLu is offline   Reply With Quote
Old 09-09-2014, 02:42 PM   #10
Pirates55's Avatar
I dropped mine off yesterday at the dealership to send it back to the factory.
Pirates55 is offline   Reply With Quote
factory
