Old 05-13-2017, 11:49 AM   #1
Shower door loose roller
I have a 2017 Columbus 383FB and the triple sliding shower door has a roller loose, how does one get to the roller to tighten? My unit is not updating on the signature box.
John & Carol
2017 Columbus 383FB
1999 F550 7.3
Livingston, Texas
Cane Raiser is offline   Reply With Quote
Old 05-13-2017, 11:55 AM   #2
SYE
SYE's Avatar
I had to drill a hole in the top rail big enough for a screwdriver to fit in. I removed the screw, put locktite back on it and replaced. 4 years and still tight
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 47 reserved
SYE is offline   Reply With Quote
Old 05-13-2017, 02:46 PM   #3
Since my door was hanging on one roller, I just titled it a bit and was able to reach up there with a ton of patience and put the nut on the back of the roller. It took about 10 minutes. Like SYE, he probably looked at removing the top cap of that slider bar to get in there but the cap is all part of the slider so no dice. It is also heavily caulked so I didn't wan to mess that up.
Drilling an access hole is a great idea too.
2017 Columbus Palomino F366RL
2016 GMC Duramax 2500 HD, PPEI Tuned, B&W Hitch
ShopDawg is offline   Reply With Quote
Old 05-13-2017, 08:55 PM   #4
Thank you, I see that will work. Did you ever find an assembly drawing on these doors. I would like to get one. Thanks again
John & Carol
2017 Columbus 383FB
1999 F550 7.3
Livingston, Texas
Old 05-20-2017, 10:29 PM   #5
We have the same trailer. Is there heat other than the propane heating system? If so, how do I turn it on??
condojj48 is offline   Reply With Quote
Old 05-21-2017, 08:25 PM   #6
About the heater
I have a wall thermostat the allows me to choose gas or electric. The gas works as always. The electric is supplied by an electric element in the AC unit. The floor unit comes on at the same time. I have been told that this to help in the circulation of air. Not too efficient. It is not a heat pump.
John & Carol
2017 Columbus 383FB
1999 F550 7.3
Livingston, Texas
Old 08-07-2017, 12:42 PM   #7
The shower doors are terrible. We are taking it out. Dh pulled up the bottom railing and its moldy but there was no way to clean it. Ton of caulking too. Still leaked under.
loribico is offline   Reply With Quote
door, show, shower
