Old 02-25-2016, 12:17 PM   #1
mikejm
Shower doors
Palomino
320RS.
3 door shower doors are stuck
Middle door is stuck to the front door. They are in their slides but do not separate from each other allowing full closure of all 3 doors.
Any suggestions are appreciated.
Thanks, mikejm
mikejm is offline   Reply With Quote
Old 02-25-2016, 12:23 PM   #2
Fulltime family RVer
Hit it hard with a hammer. Squarely in the middle.
I assure you, it'll come unstuck.
Old 02-25-2016, 05:03 PM   #3
mikejm
Ha,ha that breaks me up.
Old 02-25-2016, 05:30 PM   #4
Keisling's Avatar
This post cracks me up
-Dave
2014 Wildcat 312BHX
2015 RAM 2500 Mega Cab 6.7 Cummins Turbo Diesel
Keisling is offline   Reply With Quote
Old 02-25-2016, 05:31 PM   #5
Oh man, my follow post didn't show. mikejm, how do you mean they're stuck together? Like the glass pieces themselves are stuck?
Can you take a plastic putty knife and slide it between them?
Old 02-25-2016, 05:39 PM   #6
mikejm
No stuck together at the top. They won't pass each other at the top but appear to be in their correct slides.
Old 02-25-2016, 06:56 PM   #7
Are you able to take and post pictures? I can take some of mine and we can compare notes. If they're in separate tracks, I don't see how they can't work...
Old 02-25-2016, 07:20 PM   #8
mikejm
Here's what I have
ID:	100409   Click image for larger version
Old 02-27-2016, 12:39 PM   #9
It looks like they are both in the same slide. Look at them on the front side (toward the shower head). Be careful the metal is sharp.
Okie
Okie
Retired USMC&FAA
2015 Columbus 381FL
08 F450
USMC Okie is offline   Reply With Quote
Old 02-27-2016, 02:27 PM   #10
mikejm
Found a loose screw on middle door. Quite deal to fix. Took top bar off, doors off slides to tighten screw. Routine maintenance lesson learned. Thanks to all who pitched in trying to help. mikejm
Old 05-06-2016, 06:32 AM   #11
Geaux_Jeaux's Avatar
I have the same issue. How hard was it to take off the top rail and the doors, and to replace them? I have unscrewed the top rail and attempted to remove. but seems to be at least a 2 man job.
Geaux_Jeaux is offline   Reply With Quote
Old 12-06-2016, 03:40 PM   #12
Charles.maine's Avatar
I know this is a little old but I am sure that more will have this issue. Yes its a 2 man job. Not real hard but to much for 1 person. You just unscrew the screws on each end of the top rail and lift it out. I turned mine and took it out into the kitchen area where there is more room to work.
I actually had my middle door come off the rail. Come to find out the screws just came out. Not sure where they went. Either way....Called SEA (Shower Enclosure of America). Well actually I emailed them because I could not get thru on the phone. info@seamerica.com or 800-536-7324 They are in Ontario, California. They replied to my email quickly and gave me a call. They just asked me some simple questions describing my setup and then offered to send me new screws and rollers free of charge. Very pleased with that customer service!!
2015 Chevrolet Silverado 2500HD 4x4 Z71 Duramax/Allison Combo Pull Rite, ISR Series Superglide 16K, LoadLifter 5000 Ultimate W/ WirelessOne
Current RV: 2016 Palomino Columbus 381FL Fifth Wheel
Lippert Flex Air Pin Box, LT235-85-16 GY G614
Nights Camped 2013 - 6 • 2014 - 7 • 2015 - 12 • 2016 - 29 • 2017 - 16 (17 more planned!!)
Charles.maine is offline   Reply With Quote
Old 04-07-2017, 03:51 PM   #13
Thanks for the update. We just purchased a Columbus with the same doors. The first day the top screw for the middle door came out and we have lost another since. Bad design. How is it holding up since you did the repair?
loribico is offline   Reply With Quote
Old 04-07-2017, 04:30 PM   #14
Really good. Call them up and they will send you replacement parts. Then just get them tight. If I bought a new one today the first thing I would do is tighten up those rollers.
Old 04-12-2017, 12:40 PM   #15
BuckeyeChuck's Avatar
It probably was loose from day one.
2012 F250 Super Duty
2013 Sabre 33CKTS
BuckeyeChuck is offline   Reply With Quote
Old 05-20-2017, 04:23 PM   #16
Thank you!! I have the same [problem on my 2017 Columbus 383FB. And thanks for the contact info.
John & Carol
2017 Columbus 383FB
1999 F550 7.3
Livingston, Texas
Cane Raiser is offline   Reply With Quote
door, show, shower
