Old 09-06-2014, 08:24 AM   #1
K5bryan's Avatar
Shower leak!
We have a solaire 292qbsk and we had a giant puddle of water pouring out from under our bathroom wall into the living room this morning. I did some investigating and be love it is coming from around the control knobs on the shower. When I sprayed the water on the front wall it started pouring out inside the wall. Does anyone know if there is supposed to be caulk around where the control knobs mount to the jut out on the shower?
And the best part is that we are at Disney for a week!
Here is a pic of the control knob area that I am talking about.
Name:	ImageUploadedByForest River Forums1410009891.046898.jpg
K5bryan is offline   Reply With Quote
Old 09-06-2014, 10:28 PM   #2
K5bryan's Avatar
Something else that I saw while under the shower was the hole cut in the floor for the drain pipe. Is it normal to saw through the metal floor joist (or whatever they are called on a travel trailer)?
Name:	ImageUploadedByForest River Forums1410060482.943331.jpg
Old 09-06-2014, 10:57 PM   #3
Plain Old Member
Here's a thread I had that might interest you. Same problem, and the fix. As for the floor joint, I wouldn't think that would be normal, but who knows in today's manufacturering processes.
3 Leaks and Counting
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 09-06-2014, 11:02 PM   #4
Plain Old Member
I don't have a picture in that thread, but the whole assembly has been flipped over, where the shower hose comes out the bottom now. Just had to swap the hot / cold caps on the knobs. Water can / will get in where your shower hose connection to the faucet, and between the faucet and raised plastic piece that sticks out. It should all be sealed, but ours was not.
leak, show, shower
